• 12-27-2012
    wmac
    If you want to upgrade your Suntour fork
    From Nick at Suntour: "We are happy to provide a customer loyalty upgrade program that allows end users to upgrade to a fork of their choice from SR Suntour. Forks start at the Raidon level with an air cartridge, adjustable rebound and hydraulic lockout. Pricing starts at $150-$175 depending on the wheel size."
    More details: http://forums.mtbr.com/9960280-post36.html
  • 12-27-2012
    jetboy23
    A contact email, phone #, or website link might help. I am curious about this.
  • 12-27-2012
    wmac
    PM Nick.
  • 12-27-2012
    eb1888
    This can be a good option, but like any upgrade you need info to compare your choices before you spend your money. Fork demos don't exist.
    For upgrading it would be useful to throw out some tuning info, testing links and exploded views. I see an exploded view for the Raidon but their website links for views of the Epicon and Axion are not live.
  • 12-27-2012
    shibiwan
    :thumbsup::thumbsup::thumbsup:
    .... the word's finally getting out... Nick is going to get swamped by PM's
    hehe
    -S
  • 12-27-2012
    77charger
    Had i hadnt changed mine a while back i think i would have been all over this too.I still have my basic suntours that came on my trek
  • 12-28-2012
    burbskate
    Anyone heard back yet?
  • 12-28-2012
    wmac
    Might be off for the holidays.
  • 12-28-2012
    jimwg
    Sounds like a cool program, will try to take advantage of it as soon as I'm able.
  • 01-02-2013
    SRvancouver13
    Hi All,
    We are just getting our computers warmed up again from the holidays and I have already tried to answer PM's and email regarding this. I will get back with anyone who ask a question time permitting : )
    One thing I would like to add is that we do have a dedicated demo driver that covered more than 30,000 miles last year and attended every large bicycle event in the country so our higher end forks can be seen out in the wild.
    In regards to exploded views every fork we have made dating back to 2006 has an exploded view available on our website.
    Nick
    Here is a link to the program guidelines.
    SR Suntour North America | Consumer Site
  • 01-02-2013
    mi26r
    So if I have the XCM V3 (26")on my airborne skyhawk, what would I upgrade to?
    Sent from my DROID3 using Tapatalk 2
  • 01-02-2013
    burbskate
    I'm having a hard time figuring out what is what between the models. Looking for an upgrade for a 29er. Is coil better or worse than air? It's also hard to judge on the SR site without prices.
  • 01-02-2013
    wmac
    This is where upgrading a fork becomes difficult. Your Skyhawk was spec'd with an appropriate fork for the frame and other components on the bike. If you upgrade the fork at +$150, you will have spent 50% of the original value in a modification that will enable you to travel faster and through terrain that your brakes and wheels were not designed to handle. Then you will want to upgrade those parts and you will have spent as much or more than if you just bought a bike spec'd to your riding level and style.
    However, to answer your question, the Raidon would be the next step up.
  • 01-02-2013
    jkidd_39
    Subscribed for my fiancι's Felt Six70
  • 01-02-2013
    clk
    I think there website is down
  • 01-03-2013
    GelatiCruiser
    Thanks for (re)posting this. Their website works fine for me, and I think this is something I'd definitely like to take advantage of. I wouldn't mind being the guinea pig. ;)
  • 01-03-2013
    zebrahum
    Coil vs air doesn't define what fork is better than another. In terms of entry level forks, air forks are suggested because they are more easily adjustable and the damper systems that come with air forks at that price range are usually better than coil forks because the low end coil forks are less expensive overall. As you get into higher priced forks the dampers are what set one fork apart from another more so than if they're air or coil. I have a very nice coil rear shock mated with a very nice air fork on my bike and they have their strong points. Coils have a nice "feel" to them but weigh more. Air is more easily adjustable including on trail or for another rider of a different weight to ride.
    I would start with the SR catalog http://srsuntour-files.dbap.de/_publ...S-2K13-LOW.pdf. It has a nice description of all of the dampers used in their forks (pages 20-25) then starting on page 62 you have a breakdown of the specs of each fork. Usually, the model name contains the name of the damper used in the fork so you can know which technology is being used where.
    Here's a quick guide to picking a fork:
    1. Your frame is designed for a certain amount of suspension travel. If you do not use that amount of travel, you change how the bike handles and in extreme cases you can put the structure of the frame in danger and risk breakage. I would suggest to match the travel of your current fork and not exceed it by more than 20mm. Every frame is different, contact the manufacturer with any questions about compatibility.
    2. Buy the same steerer tube as your current fork or one that is compatible with your frame. If you have a straight 1 1/8" steerer, buy a straight 1 1/8" steerer for your new fork. If you have a tapered headtube then buy a tapered fork and so on.
    3. Match your wheel size, axle type (QR or thru-axle hub), and your brake type. If you have rim brakes, make sure the fork you're shopping for can take rim brakes.
    4. Finally, pick a price and buy whatever you can get for that price. Fork technology can get pretty hard to understand; if you are buying in a certain price point then you can compare forks more evenly. Only compare forks that contain your needs in wheel size, axle type, and so on to limit your choices as much as possible.
    All that's left is to make a decision. It's hard to go wrong so long as you don't mind a little homework. If you can't make a decision, go to your LBS and let them guide you.
  • 01-03-2013
    burbskate
    @zebrahum - wow. Thanks for the great explanation! I'll look up that catalog.
  • 01-03-2013
    NYrr496
    I have three people with XCT's on their bikes. This would be an awesome upgrade.
  • 01-05-2013
    ryencool
    so is there a website or do we just pm? my 400ht from BD has a suntour SR fork on it and its the only part on it i dont like. it has bottomed out from day one and im 5"11 160lbs. I wouldnt mind a higher end fork from suntour but the one i have, ugh...
  • 01-07-2013
    SRvancouver13
    Hi All,
    There seems to be a lot of interest in this program from many of you, so thanks. For anyone that has questions about this please email me as opposed to a PM to make it a little more legitimate.
    For anyone looking for a quick review on the base level fork in this program you can check the link below.
    Voodoo Hoodoo Review - BikeRadar
    Nick
    360-737-6450
    nmoore@srsuntourna.com
  • 01-07-2013
    motorcitymatt
    OOOOO! I will have to keep this in mind as I'm looking at new rides.
  • 01-08-2013
    GelatiCruiser
    I'm going to have to dig through the product guide and give the Raidon a good looksee. Is there a price list for these forks anywhere?
  • 01-08-2013
    SRvancouver13
    We had quite a few forks featured in the most recent buyers guide in Decline with pricing.
    Nick
  • 01-08-2013
    Krunk_Kracker
    Nick
    Screencaps from that article...
    I'm interested in the Epicon-x1 LO-RC 29"
    What's the deal with that one?
  • 01-10-2013
    Jernas
    I agree with what wmac said and would like to add that your fork is probably good enough for your needs especially if it's a HLO (oil damped) version. If you're sure it's not cutting it anymore or you find it to be too heavy (it's a heavy fork) I would suggest skipping Raidon and going to Epicon directly. That's just my opinion though it's not a rule.
  • 01-10-2013
    watts888
    I e-mailed suntour about this, but haven't heard back. Very busy holiday season I guess.
    Are there any offers on rear shocks? I've seen these on ebay.uk and occasionally here in the states, but not much.
  • 01-10-2013
    Krunk_Kracker
    Might be better to call them... Their info is on the previous page.
    Sent from my DROID RAZR using Tapatalk 2
  • 01-10-2013
    GelatiCruiser
    Can zoom in on the 1st 2 pics but the pricing and specs are blurry... Dagger!
  • 01-11-2013
    GelatiCruiser
    I'm guessing this isn't the entire line? I don't see any Raidon with air/lockout/rebound for ~$200??
  • 01-11-2013
    Krunk_Kracker
    Really? I can read them fine... odd
  • 01-11-2013
    mitzikatzi
    I just use Ctrl + (more than once) to make the page bigger and Ctrl 0 to return to normal display.
  • 01-12-2013
    blammo585
    I've heard back. You can get a 29" Epicon LO R Qlc White for $250.
  • 01-17-2013
    hOlykamOtie*
    Is this offer still live?
  • 01-17-2013
    Krunk_Kracker
    I asked in a email and they told me there isn't a deadline for the program.
    Sent from my Nexus 7 using Tapatalk HD
  • 01-17-2013
    sfb12
    There doing this program to get more publicity on there better stuff. But be warned if you have older components like me they many not be able to get you anything at all.
  • 01-17-2013
    hOlykamOtie*
    Currently I have this fork "SR Suntour XCM-HLO w/Hydraulic LO, 80mm" and I'm interested on getting their Epicon model for 26" bikes. Any ideas how much I will pay and do I also need to give them my old fork?
  • 01-17-2013
    wmac
    Nick
    360-737-6450
    you should call or email Nick.
  • 01-18-2013
    C-man23
    I did the customer loyalty plan last July and got a Raidon for $150. I believe the Epicon was $275 but it wasn't justifiable in my case. My old fork was a XCM V3 and the Raidon made a HUGE improvement. The Raidon is not nearly as pogo sticky as the XCM but of course it's not going to be like a Fox or high end Rockshox either. They do not require you to send the old fork back. I would highly recommend this program for anyone looking to keep on riding while on a budget or while waiting to upgrade to a new bike.
  • 01-18-2013
    pepin12
    Is this works for canadian too or only US?
  • 01-18-2013
    wmac
    You should call or email Nick.
  • 01-19-2013
    zephxiii
    This would be really tempting IF i actually liked my bike and didn't want to get another one. That and i just wouldn't know how 100mm would feel vs. the stock 80mm. Though i would think half of it would be negated with sag.
  • 01-19-2013
    wmac
    Depending on the bike, going from 80-100mm with a better fork might make you like it a lot more. For $150 bucks minus the probably $30 you could sell your existing fork for, it's not a bad gamble.
    What kind of bike is it?
  • 01-19-2013
    zephxiii
    It's a 2011 Hardrock Disc 26er.
    If I can get one for 150 bucks....it's VERY tempting. It's tempting just as an experiment to learn what the difference would be in having a better fork on it, and how that extra 20mm would affect the geo of the bike. I would probably like the slacker HT angle at least.
    The problem is that i don't think that bike's geo is ever going to work for me. I need something that is more aggressive XC. And most importantly I need to bump to 29er as they offer way too many things I will take advantage of.
  • 01-19-2013
    wmac
    Yeah, sell it and get a bad ass XC race bike.
  • 01-20-2013
    whoda*huck
    You got two forks with your bike?
  • 01-20-2013
    whoda*huck
    I have dogs. Wish I had people.
  • 01-21-2013
    Necrodomis
    Do you all offer anymore higher end 29" G2 Geo forks? Looking through the site, I didn't see one being G2 that I want use for my 2012 Trek Marlin.
  • 01-21-2013
    wmac
    You should email Nick.
  • 01-22-2013
    keith421
    Can someone explain this deal to me? If I buy say a Giant Revel 1, that comes with a Fork SR Suntour XCM V3, 100mm Travel, what does this do for me? I can upgrade to what forks and whats the reduced price?
  • 01-22-2013
    mitzikatzi
    :eek:
  • 01-22-2013
    eff
    Post deleted.
  • 01-23-2013
    pepin12
    Hi everyone, I actually email Nick few days ago and he answer me so, if that can help someone, here's my email and his answer...
    Hi, I just saw on the MTBR forum that suntour offers to upgrade a low level fork for a higher one for a low price. I want to know if it still on, if it's also good for Canada and if so, how it works? I'm planning on buying a new bike in few weeksand this program might help me decide.
    Thank you
    Hello,
    Thanks for your email in regards to our Customer Loyalty Upgrade program. Attached is documentation of the specifics of the program.
    Best regards,
    Nick Hannah-Moore
    Service and Warranty
    SR Suntour North America, Inc.
    14511 NE 10th Avenue, UNIT E
    Vancouver, WA 98685
    PH: (360) 737-6450
    Email: nmoore@srsuntourna.com
    Skype: srsna.nick
    Web: SR SUNTOUR Cycling
    Warranty claims and support can now be processed more effectively through our new website. Please visit it and let us know what you think!
    SR Suntour North America | // SR Suntour North America / Warranty & Service Center
    And here the attach file:
    SR Suntour Customer Loyalty Upgrade Program Guidelines
    SR Suntour North America is excited to launch a new program geared towards its North American customers. The intention of this program will allow the end user to upgrade his/her own suspension fork to something that will align better with their riding style and overall expectations than their current suspension fork.
    To participate in this program consumers are encouraged to visit the shop in which they purchased the bicycle from to make sure that the necessary upgrades make sense and that the appropriate fork is ordered to fit the bicycle and its intended use. Dealers should contact SR Suntour North America for product availability and ordering.
    For consumers that do not have the ability to work through a local dealer they are welcome to contact us directly to participate in the program and discuss fitment, pricing and product availability.
    To be eligible and qualify for the Customer Loyalty Upgrade Program one must provide the following:
    • Serial number of current SR Suntour fork
    • Receipt of existing fork and or bicycle in which the fork came stock
    • Agreement that the fork will not be resold to a 3rd party
    Forks currently available through this program include the following SR Suntour models
    • Raidon LO R Air Disc Blk 26” $150.00
    • Raidon LO R Air Disc Blk 29” $175.00
    • Epicon TAD 15Qlc 150-110 Disc Blk/White 26” $250.00
    • Epicon LO R 15Qlc White 29” $275.00
    • Axon RL 15Qlc Blk/White 26” $300.00
    SR Suntour North America 14511 NE 10th Ave Unit E Vancouver WA 98685 Phone: 360-737-6450
  • 01-23-2013
    Krunk_Kracker
    Ugh...I can't decide between the Raidon LO R Air Disc Blk 29” and the Epicon LO R 15Qlc White 29”..
    I don't really need the Epicon, but that's a damn good price for one of their higher end forks. Does anyone have any experience with this fork?
    <s>Are they both axled?</s> Nevermind, I see only the Epicon is axled.
    Does either come with a remote lockout?
  • 01-24-2013
    techGuy714
    Just got a bike with a suntour for, perfect!
  • 01-24-2013
    eb1888
    If you;re thinking about the Epicon, Nick at Suntour is the guy to talk to. I believe he rides that fork set at 110.
  • 01-24-2013
    Krunk_Kracker
    I want it but it looks like it's only offered in a 15QR through axle... For me to use that, I'd have to upgrade my wheelset.
  • 01-24-2013
    kjlued
    Looks like the only one without a thru axle is the Raidon.
    Is this true or am I missing something?
    I may upgrade to a tru axle hub on my HT anyways so I can swap parts between the bikes but just want to see what else is available.
  • 01-26-2013
    J Hartman
    so in order to upgrade the fork you have to upgrade front hub as well to a thru axle? So it is not a simple skewer?
  • 01-26-2013
    J Hartman
    {deleted}
  • 01-26-2013
    eb1888
    You need a front wheel with caps you can change. This upgrade to a light front wheel and tire will be as major as the fork. I built my own with an ArchEx rim DtSwis SuperComp spokes and nips and a ZTR hub. The Park TM-1 gauge is what I needed.
    That wheel will go on to any future bike. This is worth it because no bike until you get to $4-6K comes with decent wheels.
  • 01-26-2013
    GelatiCruiser
    I'm still trying to figure out how much my stock fork weighs and I can't find it anywhere on Suntour's site. It's the XCT V3 LTD 29er. Anyone know? I see the Raidon comes in (I think) at 2145gm or so...Just curious how much weight I'm going to save WHEN I go with the Raidon.
  • 01-26-2013
    kjlued
    Honestly if Suntour wants to up their image they need to get rid of the XCT completely.
    Most peoples first and often only experience with a Suntour fork is what comes on their budget bike. If that fork was the XCT and they rode anything more then gravel roads where they did not need a fork to begin with, then their experience was a bad one and in their mind this means Suntour makes junk.
    My first bike had an XCT and it was nothing but a glorified pogo stick.
    I realized it was a budget bike at a budget price and they slapped the cheapest piece of crap on the bike to make it look like the higher end bikes. Even though this was not a high end bike, it was not a Walmart bike either (although I don't know if it was much better than a walmart bike).
    My next bike was also a budget bike but came with the XCM.
    Although this is still a budget fork used to sell the bike at an affordable price with suspension, there is a HUGE difference between it and the XCT.
    As far as budget forks go on budget bikes, the XCM is an admirable choice and not a complete embarrassment to the company.
    All that being said, I can not see there being much manufacturing cost difference in the XCT and the XCM. I might even guess that if you dropped the XCT and started making more XCM's the cost of manufacturing the XCM would go down.
    At the very least, if you insist on continuing making the XCT then at the very least take your name off it so that gawd awful piece of junk is no longer associated with it.
    I still plan on upgrading the XCM as I do need more fork.
    However, if my only experience had been the XCT I probably would not even have considered Suntour as an option even with discounts being offered.
  • 01-26-2013
    wmac
    ^^Didn't you just start riding recently? You've got an awful lot of opinions for someone who hasn't been around Mountain Bikes very long. :rolleyes:
  • 01-26-2013
    kjlued
    Look man, I am not trying to start anything here so please don't. There really is no point in you carrying our differences from another thread in to this one. :rolleyes:
    I didn't say anything bad about Suntour. I have ridden both forks I mentioned quite a bit and have experience with both. Yes, I am a newer rider however, I understand suspension quite well from years racing both cars and motorcycles.
    That being said, as a newer rider and knowing that the XCT was junk from the very first ride, that should be more important to them then the experienced guy who has ridden $1k forks and steps down and tries it out.
    Now if you have spent some time on the XCT and would like to disagree with my opinion of it then go ahead. Otherwise I have no other reason to believe you posted that other than to try and troll me in to an argument.
  • 01-26-2013
    wmac
    First, you took a personal shot at me in a PM and I don't appreciate it. My dislike of you goes beyond just one thread. Second, your comments above were completely inappropriate, like many of your other posts.
    Third, Suntour does not choose what fork to put on a bike. Suntour builds forks and offers them for sale to bike brands. You have no idea how much the manufacturing costs are of one over another. The brands are who choose to put a recreational trail riding fork on their recreational trail riding bikes to keep costs down. If Suntour could build a better fork for the same cost, they would.
    The XCT is not complete junk. I've ridden bikes with an XCT fork and it does what it was designed to do.
    Compared to the fork I have on my bike, the XCT doesn't perform as well, but I don't go around calling it complete junk and desparaging it. If I were like you, I would go around saying your bike is complete junk and your brand shouldn't make your bike because it is bringing the brand down.
    I think there are a lot of people who expect an RTR fork to perform in a way it wasn't designed and I also think there are a lot of new riders who blame their equipment for their shortcomings.
    If you're riding an XCT, or any fork for that matter, that doesn't suit your needs, buy something different and shut up.
    This company has gone out of its way to give people who buy an RTR bike the opportunity to make that bike perform a little better with minimal cost. The only appropriate thing to say about Suntour or ANY of it's products is, "Thank you, I appreciate what you are doing," period.
  • 01-26-2013
    Hooligan63049
    I also am also new to mountain biking, have been riding for one season(1500 miles on a Trek Marlin with XCM). Wen I was shopping for my bike unless I miss understood the XCT and XCM are virtually the same fork, only difference being the XCM has a mechanical lockout. I could be mistaken. I have nothing bad to say about my lower end Suntour fork. I know it is not a top of the line item and will not offer the performance of the higher end forks. Also I think it's awesome Suntour offers a customer loyalty program such as this. Kudos to them and more companies need to have similar programs. We are in a time when many of the larger companies just don't care about their customers anymore.
    I also race motorcycles and autocross my WRX and can say that know the suspension of a car or motorcycle does not cross over to mountain the same at all. Comparing the feeling of suspension from my 410lb GSXR 750 to my 32 lb Trek is ridiculous.
    Thanks,
    Brian.
    Sent from my iPhone4 using Tapatalk
  • 01-27-2013
    kjlued
    The XCM is a fatter fork which I am sure makes it stiffer.
    Also it seems to bounce a lot less and absorb more no matter how much I played with the rebound.
    First off I have ridden both street and dirt when it comes to bikes.
    Suspension does the same basic thing no matter what it is on.
    Suspension on a dirt bike reacts very similar to that of a mountain bike.
    It just needs to do it better when on 200lb dirt bike.
    The XCT did a lot of bouncing and in no way do you want your suspension bouncing unless you are on a pogo stick. Also I am sure there was additional flex with the smaller fork tubes.
  • 01-27-2013
    bikeabuser
    Both of you should take a voluntary break from each other, before someone else decides to force such upon you :p
  • 01-27-2013
    Krunk_Kracker
    Guys... Seriously...
  • 01-28-2013
    eff
    I can add another reason to upgrade the Suntour fork. My bike has the XCM's on it and the froze solid yesterday. My buddies Zokes continued to function fine.
  • 01-28-2013
    SRvancouver13
    XCT V3 LTD was an OEM fork for Giant. We have it listed at 2575g. Just a bit lighter than a boat anchor :D
    Nick
  • 01-28-2013
    SRvancouver13
    All,
    We appreciate everyones opinion so I hope that we can keep things here as civil as if we were all face to face. I will try to answer some of the questions raised by Kijuled as best as possible in lamens terms.
    The reason for the XCT is numerous to say the least. It does suit many purposes and is a very high quality fork for the money. Remember that the XCT is a $60 dollar fork so we can't compare it to much in the market as an apples to apples comparison. It has many great features such as a coil spring, serviceable bushings and an aluminum lower casting. In some cases it even can come equiped with a lock out! Not to long ago forks at this pricing were far from servicable and were truely a throw-away type item not to mention had questionable safety concerns if it were actually taken to the trails.
    SR Suntour is the largest bicycle suspension fork manufacturer in the world. We manufacture this fork to meet certain pricepoints for our OEM clients. Some folks have limited budgets but are looking for something that will make their riding more enjoyable and fun. Any suspension is a good thing especially for a beginner cyclist. I can say this from experience as I have been in the bike industry and have been riding since the dawn of bicycle suspension. Things have come a long way thank goodness.
    Manufacturers are always looking to save cost in anyway possible so if its a few dollars on a fork or a few cents on a bottom bracket you better believe they will do it in order to get a bicycle at a certain pricepoint. It has been this way for years. Remember that it's not 1 bicycle they are saving dollars on its 100,000's sometimes more That money adds up quickly.
    The XCM does not have rebound as stated above. It will have a preload adjuster that is desinged for SAG. It has no effect on rebound what so ever.
    Anyway. I hope that clears things up just a bit.
    As for the 9mm forks. We tend to stock them at or below a $375 (Raidon series below) retail price point as the 15mm thru axle is found on high performance forks and these generally wouldn't be put on bikes that retail for the same amount of money as most would benefit from having a higher quality total package than just a fork.
    Thanks for reading.
    Nick
  • 01-28-2013
    Krunk_Kracker
    Great explanation SR!
    Another question, are any of the Epicons sold with a skewer rather than a 15mm thru axle?
  • 01-28-2013
    SRvancouver13
    We do not import the Epicon series fork with 9mm. As mentioned above forks at this price ($500+) are best to use 15mm thru axle.
    Nick
  • 01-28-2013
    Krunk_Kracker
    Nick
    Blast.
    I'd have to upgrade my wheelset to accomodate that.
    Looks like I'll be ordering whatever the best Raidon is you guys have to offer, just as soon as income tax comes in :D
  • 01-29-2013
    hOlykamOtie*
    Blast.
    or you can also check ebay, I found a Epicon fork with 9mm QR for around $200. I was planning on buying it, but plans changed.
    Here's the link if your interested. ;)
    Bi King New SR Suntour Epicon RL R Remote Lockout Disk Fork White CH06C | eBay
  • 01-29-2013
    Krunk_Kracker
    They're all 26ers and I'm not sure how much I trust that. The manufacturer said they don't make the Epicon in 9mm skewer yet there they are. Seems a little odd
  • 01-29-2013
    GelatiCruiser
    Is it an international sale? He just said they don't import them with a 9mm qr.
  • 01-29-2013
    Krunk_Kracker
    Ahh...yes. That is exactly what it is, they are all from Taiwan.
  • 01-29-2013
    bikeabuser
    Nick
    I've been thinking about this upgrade, and wondering about the front axle.
    Any chance of a seriously discounted front hub being implemented as part of a package deal ?
  • 01-29-2013
    fishwrinkle
    ~2688g
  • 01-30-2013
    joshh
    How can I figure out exactly which fork is on my bike? 2012 Rockhopper 29er. The only marking on the fork is XCR Spike Valve System SR Suntour. Specialized didn't have the 2012 info up anymore that I could find. This is the fork on their base 2013 Rockhopper. Would it be the same fork on my 2012? And if it says XCR, does that mean it falls into the same category as the XCT/XCM spoken of above?
    SR Suntour SF13-XCM-LO 29", hydraulic damping w/ lockout, coil/MCU spring, 1-1/8" steel steerer, alloy disc only post mount lower, 30mm Hi-Ten stanchion, preload adj., 80mm & 100mm travel
    Would all of the Raidon, Epicon, and Axon be upgrades to the XCR?
    And in case you read this Nick, I saw that one of the requirements was the receipt of fork and/or bike with fork on it. I bought my bike used so I don't have the original purchase receipt. I do still have the receipt from my purchase and could easily take a photo of me with bike and fork on it.....
  • 02-06-2013
    Krunk_Kracker
    Just purchased my upgrade from Nick at SRSuntour.
    Went with this one: SR SUNTOUR Cycling
    Service was great, Nick was very helpful.
    I'll report back after it comes in.
  • 02-06-2013
    chef7734
    Congrats. Wondering about this fork.
  • 02-06-2013
    zephxiii
    Re: If you want to upgrade your Suntour fork
    If u search for bike archive on their site (or in google) u should be able to find the archives and look at the specs. I was annoyed when they took it off the site nav menu.
    Sent from my MB865 using Tapatalk 2
  • 02-06-2013
    wmac
    Call or email Nick with questions.
  • 02-06-2013
    eb1888
    To get the best upgrade
    Be aware--
    Per the Owner's Manual the Raidon RL and Epicon RL models do not include a rebound damping adjuster. All the other choices do. It is a very useful feature
  • 02-06-2013
    mitzikatzi
    How can I figure out exactly which fork is on my bike? 2012 Rockhopper 29er. The only marking on the fork is XCR Spike Valve System SR Suntour....snip..
    ...snip........
    They made XCR forks in 2011 XCR RL 29'
    Yes
    XCR model forks seem to get good reviews.
  • 02-06-2013
    sfb12
    Anyone know if they sell coil forks for upgrade? It seems like the list on the last page was all air forks.
  • 02-07-2013
    eff
    Be aware--
    The Raidon X1-RL seems to:
    System Air / Hydraulic Remote speed-lock w/ rebound adjust. SR SUNTOUR Cycling
    Definately something to confirm before ordering.
  • 02-07-2013
    Krunk_Kracker
    There seems to be three Raidon coil forks available.
    SR SUNTOUR Cycling
    SR SUNTOUR Cycling
    SR SUNTOUR Cycling
  • 02-07-2013
    eb1888
    Further down in details it lists rebound adjustment-- N/A
    It seems like it certainly should have an adjustable rebound damping circuit.
    Maybe we can get some confirmation of the design for this and the Epicon.
    Fork info is hard to deciper for all the acronyms and unexplained mechanisms at work.
  • 02-07-2013
    SRvancouver13
    Be aware--
    This is incorrect information. The Raidon's and Epicon's do have rebound adjsutment. I understand that our series of forks can be a little confusing as we offer forks in several options. Please don't hesitate to contact us directly for the facts on our forks.
    Nick
  • 02-07-2013
    SRvancouver13
    Yes we do have a few Raidon's with coil spring. these are limited in quantities so feel free to call about pricing and availability.
    Our website has litsted every fork we make for aftermarket. This does not mean that we stock them here in North America as there is a lot of overlap and no need to stock certain models. The forks posted earlier are what models we have that qualify for the upgrade. We do have a few other optoins not on that list so if your interested in something specific drop us a line.
    Nick
  • 02-13-2013
    Krunk_Kracker
    Got my Raidon X1 in. It's very nice and quality. Looks good, it's getting put on tomorrow. Can't wait to try it this weekend.
  • 02-13-2013
    Mr. Brown
    ^^ Nice looking fork. In my area of the world a lot of folks use the Suntour Epicon because it is cheaper than other brands. It's also light and plush and you can adjust travel internally if you don't have the travel adjust version. Here's a video of James Doerfling riding his Epicon-equipped Knolly: Two Laps on the Endorphin - Pinkbike
  • 02-14-2013
    wmac
    Looks great! Let us know what tangible results it gives you (how much faster, less fatigue, etc.).
  • 02-14-2013
    Krunk_Kracker
    The owner of my LBS basically said the same thing, that it's unfortunate because Suntours ship on lower end bikes in the US, and to keep the price low, they put on the lowest of the low quality, and that it's not SRSuntours fault, they are just filling orders for the manufacturer. He was telling me how he has friends out of country (Canada, England and a few other places) and SRSuntour seems to be much more popular there.
    I'm going on an all day outing with my daughter and some friends on Saturday, so it'll definitely get well tested. I'll be sure to report back for the benefit of others.
    The guys at my LBS were impressed with it.
    They seen it and were saying "This is Suntour?? Wow, this is much better than the ones that come on the Scotts we sell", so they were totally impressed with the build quality. I think that is what SRSuntour is hoping starts happening.
    If I really like this Raidon (and unless it's an utter failure, I can't think of any reason why I wouldn't), I'll continue to use SRSuntour. I'm planning a Niner build next year and will most likely use a Epicon.
  • 02-14-2013
    wmac
    A lot of people forget RockShox were in the same boat a number of years ago. The pendulum swings. Glad to hear we were able to get you on better equipment for a lot less $$$ than the traditional ways. Plus, you have a warranty!
