Results 1 to 12 of 12
Thread: If I can...
    Always good times....
    If I can...
    If I can pick up a Shimano Saint RD-M800 Rear DRLR 135mm, for under fifty dollars bran new then should I pick it up as it stands I have a Shimano Acera RD-M340 and I am not happy with it at all it came stock, but not happy with it my question is the Saint RD-M800 something that will last me through a lot?
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Doesn't the Saint derailler require a special hub? I believe that's the case up through 2008. Thus, I do not believe you will be able to just "drop in" a Saint as a replacement for an Acera.
    hmm i will look into that thank you...
    Shimano FH-RM30L, cassette, 32h, QR this is what I currently have for a rear hub, if anyone could give me a quick answer i would appreciate it.
    Ride the dream
    Reputation: EnglishT's Avatar
    No, you dont want saint (youd need to get alot more than just the mech)
    Besides which, its designed to get hit and survive - that makes it heavier than youd need.
    An XT or LX would be a better choice - and still a VAST improvement on Acera
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    The RD-M800 Saint requires a special hub. They are being blown out super cheap now because nobody wants them, and the new 2009 Saint that about to be released went back to standard mounting.
    Jun 2005
    If you are looking for a closeout upgrade, here is an LX for $32
    http://www.jensonusa.com/store/produ...erailleur.aspx
    This derailleur will work with your setup, but it's "Low Normal" which means it will shift backwards from what you currently have.
    Oh okay so if I was to want a saint I would have to wait for the 09 version and so on, but I will look at he LX.
    Ride the dream
    Quote Originally Posted by oldskoolbiker
    This is indeed a very good deal.
    You'll also find that the rear mech makes alot more sense that way around - once you get used to it.
    Now if only theyd make a shadow rapidrise...
    I guess the real question is would you wait for ther 09 or go with a LX
    Jun 2005
    Quote Originally Posted by gijoetx
    Actually the '09 version is out:
    http://www.pricepoint.com/detail/181...Top-Normal.htm
    But I wouldn't recommend it for you. Its super beefy for DH and freeriding. Also it won't work too well with a triple chain ring in the front, so you would need to be using a double or single.
    If you wanted something beefier for your normal mountain bike I would get the SLX.
    http://www.pricepoint.com/detail/180...Top-Normal.htm
    Ride the dream
    Dont go saint - its really not worth it for anything but REALLY heavy use.
    To be perfectly honest, SLX is a bit more beefy - but XT/LX are plenty durable enough... For the difference, that money could be spent upgrading elsewhere. If your bike came with a low end drivetrain, theres bound to be plenty of things that would benefit from an upgrade (no offense).
    Also - I would jump on that LX mech, the deal is incredible
