Results 1 to 16 of 16
    Oct 2010
    Hydrolic Disc Brake Piston offset?
    Hi MTBR.
    I am a noobie with Hydrolic disc brakes, and i dont know how to explain this very well, but i saw that the pistons on the hydrolic disc brakes are offset, and are already pushed out, even with no brake applied
    are the pistons supposed to be like this? or are they supposed to go back into the piston hole all the way?
    thanks
    Matt
    Reputation: mtbnozpikr's Avatar
    It depends on how much they are sticking out. They should be more or less flush with the caliper so you probably have a problem. What kind of brakes are they? It sounds to me like you have an issue with sticky pistons. It's an easy fix though assuming that's the problem. Pull your wheel, take your pads out, and clean up the pistons really well with rubbing alcohol. Lubricate the clean pistons with brake fluid, wipe off the excess so you don't contaminate your pads upon installation, install them, put your wheel back on and you're good to go. A bleed may not hurt either but that may be better for a shop to do.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    Reputation: faceplant72's Avatar
    most hydrolics self adjust so as long as there is no brake rub offset is fine. Be careful not to activate the lever with a wheel removed or you will have to pry the pads apart.
    Quote Originally Posted by faceplant72 View Post
    If you pull the lever with the pads out, you could lose your pistons and then all of the fluid so as mentioned, don't pull your lever without a rotor in place and especially not without pads.
    2012 Intense M9
    2008 Look 595
    Oct 2010
    Quote Originally Posted by mtbnozpikr View Post
    They are sticking out about 3-4mm give or take. so i do believe i have an issue.
    I have the Shimano Deore LX hydrolic brakes.
    How would i clean the piston? would i pull them out completely? Ah, ive done a few bleeds before, so im fine, but this is the first time i really did notice the pistons sticking out so much. so i got alittle freaked out.
    Oct 2010
    In the event that i do accidently pull the lever, while pads and disc are out, what should i do, if the piston does fall out?
    Alright, it is easier to clean them than to bleed them. If you have cotton balls or q tips and rubbing alcohol you should be good. Just wipe them off really well and since they're sticking out you'll be able to get the sides of them as well. I asked you what kind they were so I could determine what type of fluid you're running. Mineral oil is what you need to lubricate them with as you probably already know. I just didn't want you to put DOT fluid on a mineral oil brake (you'll be in the market for new brakes a lot sooner than you thought).
    You shouldn't accidentally pull the lever. It should not be an issue at all, just don't do it. Assuming you already did and the piston already fell out, you've got a bigger issue. To be honest with you I've never had the problem because I have never pulled a lever with no pads in. I think; however, that you can push your pistons back in and then do a bleed assuming you didn't tear your seals. I'm not positive though. Again, it shouldn't be an issue if it's not already.
    2012 Intense M9
    2008 Look 595
    Oct 2010
    Awesome, thanks! Hopefully this is the problem. if not, i will report back.
    Alright, don't worry, i havent, its just once, my shirt caught onto the lever, while doing a bleed and i was glad i had a spacer in the brake.. i was wondering just in case
    Quote Originally Posted by Mattlikestobike View Post
    Great, good luck.
    2012 Intense M9
    2008 Look 595
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    You probably don't have a problem. Hydraulic brakes self adjust for wear so that you don't have to pump up your brake lever in order to stop when your pads get worn out. Your car brakes work on a similar system, self adjusting for wear.
    As long as the pistons are coming out of the caliper roughly the same amount you are good to go. If you ever get worried, take a CLEAN tire lever and gently and evenly pry the pistons back into the caliper body and pump the lever back up. Always a good idea to clean the pistons before you press them back in.
    Hi MTBR.
    thanks
    Matt
    The pistons self-adjust for pad wear. The thinner the brake pads get, the farther out the pistons stay. They only retract a small, set amount to keep the gap between the pads and rotor consistent. If the pads are thin, the pistons will stay partially extended out of the caliper. Otherwise, the free lever travel would increase as the pads wear.
    You will have to push the pistons all the way back into the calipers when you install new pads to gain the necessary clearance.
    If your brakes are working OK and not rubbing the rotor, they are fine.
    Edit...beat again due to slow typing skills.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by gmcttr View Post
    Typing classes in high school pay off again!
    Quote Originally Posted by zebrahum View Post
    That's a good point with regard to the self adjusting pistons. It definitely depends on how your pads are as well.
    2012 Intense M9
    2008 Look 595
    Oct 2010
    Oh, glad i havent touched my bike yet then.. Since my pads have about 5-10 mm on them left and need changing soon.
    How much spacing should there be inbetween 1 pad, and 1 side of the rotor? i have give or take 1-3mm
    If you've got 1-3mm you're golden. As people mentioned, if your pads aren't contacting your rotors, you're good. Assuming 1-3mm, that's plenty of space.
    2012 Intense M9
    2008 Look 595
    Oct 2010
    awesome, thanks!
  1. Replies: 7
    Last Post: 01-21-2010, 02:51 PM
  2. Hydrolic brake conversion
    By MTBgreatfalls in forum Brake Time
    Last Post: 02-21-2009, 03:17 AM
  3. New Hydrolic Brake From Atom Lab
    By cacorro in forum General Discussion
    Last Post: 06-19-2008, 06:08 AM
  4. Sticky XTR Disc brake piston
    By OffRoadRoadie in forum Brake Time
    Last Post: 05-06-2008, 09:01 AM
  5. Hydrolic Brake fluid
    By extrmtao in forum Brake Time
    Last Post: 06-05-2006, 12:50 PM
