Results 1 to 7 of 7
Thread: How to roost?
    How to roost?
    Im curious how people roost on a mountain bike. Even if i knew how i would rarely do it since its not good for the trails
    Are you talking about when people lock up rear brakes to slide the tire in a turn throwing dirt up? if so, that's your answer, lean bike -lock brake. Sometimes, some riders have true loamy dirt and they don't have to do that as the dirt is loose and just breaks out.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Rogue Exterminator
    Reputation: kjlued's Avatar
    Quote Originally Posted by bank5 View Post
    And sure, it is ok to intentionally tear up the trails but only if you "rarely do it".
    Just stick it in granny and start grinding.
    Real roosts don't involve locking up the brakes - that would be a skid, or "powerslide" as we used to call 'em when we were kids. You need to learn to turn fast and hard enough to break the wheel(s) loose. A quick counter-steer going into your turn helps. Get ready to high-side it a ton of times trying to learn; pretty tricky move.
    Reputation: jimbowho's Avatar
    Dec 2009
    I thought roost was an offroad term. Your riding your kids PW-50 to sign up, your buddy can't help himself, on his KX-500 with an IRC-M5B-140-80-18 tire (fresh mount) he slices under you grabs clutch and 2nd gear and roosts you.
    Quote Originally Posted by jimbowho View Post
    Basically, the 'roost' is the dirt thrown by a spinning tire (ie - moto chest protectors are know as "roost protectors", as they keep a lot of racks and crap from peppering your sternuem). Since it's not likely there are a lot of mtbers that can put enough power to the pedal while moving in straight line to throw a roost, you have to take it to the turns. I'll see if I can find a good slo-mo vid of somebody pulling it off - I know I've seen them. Key factor though, is the wheel's gotta be spinning while throwing dirt. Skidding doesn't count.
  1. Owl's Roost
    By Dresdenlock in forum North & South Carolina
    Last Post: 10-18-2011, 11:01 AM
  2. How are Owl's Roost/Wild Turkey?
    By 7daysaweek in forum North & South Carolina
    Last Post: 01-08-2011, 04:42 PM
