FAT BIKES
WINTER APPAREL
TRAINERS
Page 2 of 2 FirstFirst 1 2
Results 26 to 32 of 32
  1. #26
    Nov 2012
    Quote Originally Posted by faceplant72 View Post
    But have you been able get your Summer air yet or are you still using the winter mix. The oxygen in the winter mix really kills performance
    It's winter downunder so no summer mix available but luckily I followed Manbat's advice and bottled all my farts this summer. The fork is unbelievably plush and small bump compliance is greatly enhanced. And my tires almost float and appear to just glide over trails.
  2. #27
    Reputation: Gasp4Air's Avatar
    Quote Originally Posted by Kiwi_GR_Biker View Post
    THat's because rocks and roots smell them coming and get out the way.
    Use it, use it, use it while you still have it.
  3. #28
    I use helium to make everything lighter.
    Seriously though, I'm a squeeze with my hand to see if it's close enough. If it needs it I'll get the pump.
  4. #29
    Reputation: 006_007's Avatar
    Quote Originally Posted by manbat View Post
    I capture all my farts in an old irn bru bottle and save them up till theres about 80psi in there...then I inflate my standard tyres on ztr flow rims...they ALWAYS inflate super easy and stay up for months
    That sounds like a potential W.M.D. there - careful as they went after Sadam for less then that.......
  5. #30
    Reputation: borabora's Avatar
    If you inflate to higher psi then you will need to top off more often. On a road bike I have often pumped to 110 psi then ridden the bike for 4 hours and measure the tires at 90 psi the next morning. Obviously you won't lose 20 psi in 24 hours on a mountain bike if you inflate to say 28 to start with. More likely you lose a similar percentage.
    Also keep in mind that if you use a CO2 cartridge to fill a tire you will need to fill up with air asap as CO2 is lost at 2x-3x the rate of air. Here emptying your tires and refilling may actually make sense aside from amusing people.
  6. #31
    Apr 2013
    Before every ride since most of my different rides require different air pressure.
  1. Switching from off road tires to street tires...suggestions?
    By bpreachers in forum 29er Components
    Last Post: 04-13-2013, 11:35 PM
  2. Question about Schwalbe tires to replace stock tires
    By bosco0633 in forum 29er Components
    Last Post: 03-06-2012, 08:40 AM
  3. Replies: 4
    Last Post: 10-07-2011, 06:04 PM
  4. Narrower tires for an older MTB? (off-road tires)
    By Medic Zero in forum Wheels and Tires
    Last Post: 09-10-2011, 09:25 PM
  5. Wider tires, less rolling resistance, what about taller tires
    By HighLife420 in forum Wheels and Tires
    Last Post: 06-01-2011, 07:23 PM
Follow MTBR on Facebook
