Results 1 to 6 of 6
    Jun 2013
    How much should Fox float rear shock travel & can too much pressure damage shock?
    Hi, i have a giant trance 29 x0 (2013). it has a Fox Float CTD Boostvalve perfomance, which is 2.25 inches in length i think.
    If I pump up the rear shock, until i can't pump it up no more...close to 200 psi, and then a ride around on flat ground in parking lot the shock travels about 1 inch in climb mode.
    1inch/2.25 = almost 50%, without going over any bumps, with a high psi, and climb mode! Is this normal, or do i have a defective shock? I would have hoped that the rear shock would be closer to locked out in climb mode. i'm only about 170 lbs.
    Also, when i was trying to pump up my shock a while ago the pump broke as i was reaching psi's close to 200, which i hadn't done before. So if you can damage a pump by going close to 200 psi, can you also damage the shock?
    Moderator Moderator
    Go to Google and type in the name of your shock and the words "set up" after it. This will help you find your way to the Fox website where they will tell you exactly how your shock works and how to set it up.
    FWIW, just 'pumping it up until you can't pump it no more' and thinking it's going to work leads me to believe you might be better off with a hardtail.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    You add air to it per sag for your weight.
    The climb mode is in essence to "slow" down the compression of the shock to make climbing better.
    Too much air does nothing good for the shock or the riding experience. If you like a firm rear end ( ) go with a shorter travel bike (Giant Anthem/ Spesh Epic) or a hard tail.
    Mar 2014
    200 PSI and it can't go any further? Most shock pumps go to at least 300 PSI it could be the type of pump you're using. If you have no CTD control i.e. you put in in climb but you still have full travel your shock may be cavitated and will need to be serviced. If your shock is maxing out at 200 PSI there is also problem with that shock that will require factory service. It would be very helpful if you could provide body weight and pump type.
    Stupid question but you're using a shock pump, right?
    '15 Specialized Fatboy
    '14 Kona Zone Two
    '13 Surly Big Dummy
    Fat-tired Roadie
    Nov 2007
    The way I understand climb mode, it doesn't lock out the shock at the top of its travel. It just makes it take a very long time for it to move. Maybe even on the order of two minutes. Even out of the saddle, your cadence should probably be on the order of 60 rpm, or 120 little hits. So a damper setting that makes the shock that insensitive would filter that out pretty completely.
    It also still has a blow off valve to prevent damage.
    Does the shock make any weird noises? What if you try setting sag normally? Have you had it on trails?
  1. Variable Travel on Fox Float Shock
    By mattangeles in forum Shocks and Suspension
    Last Post: 06-10-2014, 11:22 PM
  2. Replies: 5
    Last Post: 07-16-2013, 02:37 AM
  3. Replies: 0
    Last Post: 06-26-2013, 05:24 PM
  4. Fox Float (fork and shock) Air Pressure
    By alexk243 in forum Shocks and Suspension
    Last Post: 04-07-2012, 07:22 PM
  5. low pressure in rear shock
    By xdeity in forum Beginner's Corner
    Last Post: 01-10-2011, 06:31 PM
Members who have read this thread: 4
