How much difference does 30mm make for handlebars?
Getting a new bike with 750mm bars. Thinking of going wider, maybe 780mm Renthal Fatbars. Would I notice much difference?
It's noticeable, but not enough to buy a new handlebar for. That's only a little over 1/2" on each end.
At over 700mm or more, I'd sooner switch out a handlebar for a more agreeable backsweep, than for 30mm of width. JMHO
That's what I was thinking, thanks for the input. Is there a good way to figure out what's agreeable without having to go through an expensive trial and error?
If you've got lock-on grips, you can probably move the grips out a bit to simulate the 1/2" on each side and see how it feels.
Very noticeable if you pass between trees that are 760mm apart.
As mentioned, you could slide lockon grips/controls out .5inch to simulate.
Didn't you just buy a new bike?
My Kore Torsion started out as 810mm. I instantly fell in love with the feel & told myself I would never cut 'em down regardless of a few close-calls I had with trees. It wasn't till I actually had a bad crash that I decided to lobb off an inch on both ends bringing my bar to 760mm... haven't done a real ride with it since, but we'll see how it goes.
I went from 711mm to 750mm and the difference was very noticeable (for the better), I think if you were to go for the 780mm Renthal Fatbar the 30mm difference would be marginal.
I would say ride the 750s for a while see how you like em. You could always go for the 800s or 810s and chop em down to 780.
Same bike, it just isn't here yet! ...I bought it way before release. Anyways, moving the grips on my current bike out tells me that 31" (787 mm) is a near perfect fit so I've been thinking of just starting out with some 780s, maybe 785s, so I can just sell the stock bars as new...or...I guess I could just get the 780s and throw the 750s on my other bike (currently has 711s).
Yikes! 780 seems like the sweet spot for me, I think I'll go for em.
So now, race face atlas? Or fatbars? I'm open to other suggestions too. Everybody please weigh in!
I REALLY like the Niner Flat Top Carbon 780 bar. Been hammering on one since April and it is super comfortable, both ergonomically, and it absorbs a lot of chatter.
By Snototter in forum North & South Carolina
Last Post: 07-31-2013, 01:42 PM
By Maadjurguer in forum Arizona
Last Post: 06-26-2012, 12:23 AM
By Waterat Pat in forum 27.5
Last Post: 04-04-2012, 12:57 PM
By ghost_rider_x in forum 29er Bikes
Last Post: 11-07-2011, 08:41 PM
Last Post: 01-27-2011, 10:11 PM
- You may not post replies
- You may not edit your posts
Forum Rules
