Results 1 to 6 of 6
    How many bolts does my chainring have?
    I'm not sure whether its a chainring or crank, but its the pointy thing. I want to install a bash guard on my 2005 trek 3900, but I don't know how many bolts it has. How would I find out? From the look of it, it looks like it has 6 silver screw things, and 4 empty wholes. This is probably a crappy description, but I'm new to this. Can someone tell me how to find out?
    BTW I have a "SR 42/34/24" crank
    Reputation: dir-T's Avatar
    Find the thing with all the teeth on it that your chain wraps around. That's called a chainring and you have 3 of them. Now look where the biggest chainring attaches to your crank arm. The crank arm the thing with the pedal screwed on to the other end. The chainring should be attached to the crankarm with either 4 or 5 bolts. Count those.
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    Or your chainring could be riveted on
    Quote Originally Posted by dir-T
    Hey, thanks for the advice man
    Quote Originally Posted by coiler-d
    Ooooh. Good point. I just went to Trek's website and it does look like your chainrings are riveted to the crank. So you can't put a ring guard on there unless you upgraded to a different crankset.
    That's not such a bad deal though. Plenty of people (like everyone that I ride with) ride without a ring guard. Save that money and when/if you wear out or break the one that's on your bike you can by a stronger, lighter, better shifting crank. By then you may realize that you don't want a ring guard at all.
    Ya, from the look of it, there's 6 bolts. I may as well just upgrade the crank i guess.
