Results 1 to 28 of 28
    How long till I decide to take this whole box of parts to my LBS
    I used to do all types of maintenance and a bike build or two. I know I should be able to put this together. As soon as I put the v brakes on they bottom out before they should, what ? Never heard of such a thing. If I'm having trouble with this what happens when I get to something I've never done before?? Like the bar end shifters?? How long before I totally give up and take my box of parts to the LBS! I really want to do it myself, so anyone know why my v brakes won't cover the brazon?
    pics are always helpful
    Reputation: coopdad's Avatar
    When you say "bottom out" are you saying the brake lever hits the handlebar before the brakes start working?
    Please visit my bike blog! And if you click a few banner ads, I wouldn't complain!
    http://realworldbiking.blogspot.com
    Are you using the right levers? If you are trying to use canilever levers with v-brakes the cable pull isn't the same, you need to be able to pull more cable for the v's.
    i also unicycle
    are the brake arms/mounts bottoming out on the mounts on the fork/frame? sometimes there's a bit of paint or a burr there that needs to be filed down.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    What I ment was...
    I haven't even put the cables on it. I just slid the brake over the braze on and it felt like, and looked like the brakes didn't cover the braze on. I did take photos but will have to post tomorrow. I'm also going to look at my other bikes and see if they have as large a space between the brake arm and the frame.
    I thought I'd be able to add a photo of a typical braze on brake boss to show the area but I'm having trouble finding one that doesn't have the brakes already attached. I'm sure this is going to be something that I'm doing that is completely stupid on my part.
    better than I deserve
    Reputation: roblee's Avatar
    What kind of frame? Are they the old roller cam or U brake mounts and not V maybe? I have a bike with XT U brake behind the bottom bracket and it is not compatible with V brakes.
    Its a Surly frame '11 LHT and the V-brakes are from 2000 maybe. I feel like I'm missing a washer that goes on the brake boss first or something.
    Make sure that the pin on the v-brake arm is in one of the braze on holes. Some frames come with 3 while others come with just one. I'd make sure it's in the middle one if there are 3.
    hope this works
    I've never attached an image before I hope this works. On the right is a Deore V-brake with a taper that is the same as the brake boss. On the left is the XT V-brake no taper so it hits the boss where it gets larger at the bottom. Is there part of this V-brake that I'm missing??
    I only have one Deore V so I still need to use the XTs Anyone know how I can do that?
    Attached Thumbnails Attached Thumbnails How long till I decide to take this whole box of parts to my LBS-img_0397.jpg
    Yikes this image is really large! Well, you can certainly see what I'm talking about...
    You aren't missing any parts. I've attached a pic of the back of my XTR brakes which are basically the same.
    I think I understand what you are explaining, and without actually having my hands on it and looking at it, I think as long as the brake arm is on there and the pin is flush in one of the little holes next to the brazeon, you are good to go.
    You could take it to a shop if you still feel uncomfortable about it. I mean, don't let them fix it, just have another set of eyes/hands look at it for you.
    Attached Thumbnails Attached Thumbnails How long till I decide to take this whole box of parts to my LBS-earlyjulymadness-037.jpg
    The thing that I don't like is that they feel they wiggle around a bit on the brake boss and that there is some bare metal of the brake boss that is exposed to the elements. I'm taking one set down to the LBS to see what they think.
    Cool deal.
    Might wanna bring the frame with you just so they have a reference point.
    Good luck and let us know the outcome.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by Hartmame View Post
    Probably a good idea to take it to the shop, but if they didn't have any play when you put them on the posts then they wouldn't move when you tighten down the brake fixing bolt. You don't want them installed so that the brake fixing bolt can be snugged down against the brake arm, that would keep the arm from moving.
    Something`s not adding up with the XT arm where is the tension adjustment? Does not look like other V brake designs I have seen? Clean parts are happier parts..lol
    It feels like something isn't right to me as well.
    Attached Thumbnails Attached Thumbnails How long till I decide to take this whole box of parts to my LBS-img_0403.jpg
    These are BR-M750 parallel push style. They don't even make them like that anymore as far as I know.
    http://techdocs.shimano.com/media/te...9830611886.pdf
    Paint the part that shows
    LBS suggested painting the bare steel of the boss that isn't covered by the brake arm. What did they do back in the day?
    I don`t see now those will ever work right.After studying the your pic and pictorial you posted I think your are missing a spacer on the bottom side that makes it fit the brake boss properly.?
    Take a picture from the side with the brake arm on the frame that shows the gap bwteen the arm and the bottom of the boss.
    How big is the gap?
    Also note, the brake arms are fine. Nothing is missing, nothing is out of place.
    Do a search on the internet for br m750 brakes and you'll notice that all of the brakes look just like the one you posted.
    Attached Thumbnails Attached Thumbnails How long till I decide to take this whole box of parts to my LBS-br-m750_2.jpg
    Quote Originally Posted by roblee View Post
    The tension adjustment is via an allen bolt on the side which puts pressure on the leverage arm. This is also shown in the pdf tech doc he linked.
    My XTRs are basically the same as those XTs.
    A quick question for my understanding.
    Are you using an XT arm and a Deore arm on the same side(for instance, a left xt arm and a right deore arm)?
    Or are you using a full XT set in the front (or rear) and a full Deore on the other end?
    I have two full sets of the XT brakes for my bike. I only used the Deore brake arm as an example of what I was expecting the end of the brake arm to look like and what is causing the gap.
    I didn't see a spacer or washer on the tech spec sheet. Since the brake arm doesn't flair to cover the bottom of the brake boss, it is that bottom section of the brake boss that is unpainted and left exposed to the elements. Are you guys thinking I should find some kind of washer or spacer rather than painting the lower section of the brake boss?
    I completely understand what you are talking about.
    Don't put a washer there, it was not designed to have one.
    Take a pic of the gap (a pic of the brake arm on the post) so we can get an idea of how much we are talking about here.
    I've tried to get a photo a few times and just end up with a blurry mess. I think I need to try another camera. I will post as soon as I get an image that is clear.
    Off hand, I'd say the gap is the least of your worries.
    Does the adjuster base pin engage the retaining hole enough that it isn't going to slip out?
    When you tighten the mounting bolt, does it bottom out on the post like it is supposed to, without binding up the arm? Is there minimal play in the arm after the bolt is tight?
    If all these things are true, then I don't see a problem with some paint or even a good gob of grease in there.
    I just looked at the post on a newer fork and the step at the base is very small, much less than a 1/4 inch. On another fork that used to have cantilevers on, the step at the base is much larger, more than a 1/4 inch high. Sounds like the Deores are designed to be adaptable where as the XT are designed for newer posts.
  1. How long till bearing replacement?
    By zod in forum Ventana
    Last Post: 02-18-2009, 12:07 AM
  2. How long till I like it?
    By dwnhlldav in forum 29er Bikes
    Last Post: 06-30-2008, 12:41 PM
  3. How long till Fork Springs wear down?
    By Molasses in forum Shocks and Suspension
    Last Post: 07-22-2006, 10:15 AM
  4. How long till the trails are dry?
    By sodade in forum Arizona
    Last Post: 10-21-2004, 07:26 PM
