    How to gear back a twist shifter?
    A very beginner's question: the twist shifter wheel only spins forward, how do i shift it back? it does not seem to spin backward. thanks!
    mbtr member
    Reputation: scottzg's Avatar
    twist it the other direction
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    the problem is it's like stuck and can't be twisted back
    and i know it's not the bike's problem as it's pretty new.
    Reputation: Timon's Avatar
    either you're not using enough force to twist it back, or its broken.
    if you're semi-constructive you can probably take it apart and find the broken/dislodged part and fix it...or find out what needs to be fixed. if not, buy a new one.
