Results 1 to 3 of 3
    Feb 2006
    How do you remove a headset?
    How do you remove a headset from the head tube? I awnt to replace it. Can I get any brand of a threadless headset? Thanks
    On MTBR hiatus :(
    This is the setup I used successfully for the past few years on a number of bikes.
    (MkIII) Homemade Headset Tools...
    <img src="">
    Some folks use a long screwdriver and tap the cup out slowly. Or you can buy a proper headset cup removal tool for around $25. Lastly, there's the bike shop route, which is fine -- just depends on how self-sufficient you want to be.
    The copper pipe trick was cheap to make, and worked great for every headset I've used it on except for steel cups. Prior to the copper, I made the same out of PVC pipe. The PVC breaks and needs to be re-cut frequently, but it's easier to saw than copper.
    MTBR Hiatus UFN
    Reputation: Kaba Klaus's Avatar
    Cool tool! But you also need a tool to set the race. PVC pipe works fine for that, too.
    To the other question: Yes, you can use a headset of any brand. Headsets are standardized. But you have to make sure you do get the right type of headset.
    Integrated versus non-integrated
    Same diameter of the head tube - usually a 1 1/8 for MTB. Some have 1.5 though
    Compatible stack hight (in case the steere tube got cut very short)
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
