Results 1 to 7 of 7
    Jul 2013
    Help - Strange Dropouts - remove rear wheel
    Hello,
    Please help me, I can't for the life of me figure out how to remove my rear wheel for repairs. I've never seen drop outs before and don't know the correct way to go about removing the wheel.
    So far I tried to unscrew the center bolt which then allows me to pull the long bolt from the wheel, but I can't pull it out all the way.
    Should I be using the star key to unlock the drop out?
    I tried searching the net, but all I get is conventional drop outs and quick releases.
    Bike is Transition Bank.
    http://i.imgur.com/ipMpknah.jpg
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    If there is a lever on the other side of the axle from the pic you posted, pull the lever away from the bike, and then the wheel should slide down out of the dropouts. You will have to move the derailleur a little for the wheel to come all the way out.
    The Easiest Way to Remove and Install Your Rear Wheel - YouTube
    If it's not a traditional qr lever, then put a wrench to it. Need to see a pic of the other side.
    Reputation: Nakedbabytoes's Avatar
    Those look like they might be locking skewers. They usually require a hex wrench or torx wrench inside the center area(the hole in the middle). Or they come with a key.
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Jul 2013
    Hey guys,
    Thanks for the replies. This is not a quick release drop out. The other side looks just like the one in the pic.
    This is when I tried to pull the center rod out.
    http://i.imgur.com/HUw9y44.jpg Left side (upside down)
    http://i.imgur.com/ipMpknah.jpg Right side
    R.I.P. DogFriend
    It's a through axle. Pull the whole axle out.
    Jan 2013
    Quote Originally Posted by Smdqt View Post
    Hey guys,
    You gotta pull the whole axle out...
    Jul 2013
    Thank you guys, I was directed towards Shimano e-thru dropo out manual.
  1. Best way to remove lefty front wheel?
    By C-dog in forum Cannondale
    Last Post: 06-08-2013, 12:47 PM
  2. Is it hard on the derailleur when you remove you back wheel often?
    By BoomerBrian in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2012, 07:46 PM
  3. Replies: 3
    Last Post: 03-14-2012, 04:03 AM
  4. Afraid to remove the wheel
    By JonathanGennick in forum Brake Time
    Last Post: 03-13-2012, 07:35 AM
  5. cannot remove wheel from Lefty
    By mcoen in forum Cannondale
    Last Post: 10-20-2011, 02:04 PM
