1. The most important thing about buying a new bike is to make sure it fits. The only way you'll know if the bike is right for you is to size up the bike and make sure that the bike's geometry matches your body's geometry. Ask questions and do some research.
mtn. biking 101
2. If possible, try to find a shop that will let you demo the bike on real dirt. Five minutes in a parking lot won't cut it. You wouldn't buy a car without a real world test drive, and a bike should be no different.
3. Don't belive the hype. Just because your favorite rider or best friend rides a certain bike, that doesn't mean that's the best one for you. Have an open mind and be realistic about your needs and ability.
    help with rigid fork conversion
    So i got a 2006ish trek 3700 for dirt cheap and am setting it up as a commuter. Its currently got a old RST Capa fork thats a little scary so I am thinking of snagging a cheap rigid fork off ebay but am unsure on how long it needs to be to work right on this bike so am looking for some help
    2006 Trek 3700 - BikePedia specs for the bike looks like a 53mm travel fork is what came on it but bikepedia says its a different fork then what i have on mine.
    If you have sex in a car with airbags....does that count as safe sex???
    anyone??
    here says for a 100mm shock the rigid should be around 440-450mm on the rigid.. so take the length of travel from yours and that should be a ball park..
    What rigid fork to replace 100mm suspension fork?
    Reputation: Joules's Avatar
    just using a tape to measure the axle to crown on your fork would get you reasonably close. The replacement doesn't have to be exactly the same either.
  1. Replies: 21
    Last Post: 03-18-2013, 11:44 AM
  2. Which rigid fork size for 650b conversion?
    By zarr in forum 27.5 - 650b
    Last Post: 03-03-2013, 08:17 AM
  3. Replies: 44
    Last Post: 10-03-2011, 07:48 AM
  4. SS/Rigid fork conversion, sell me on it?
    By dstaks in forum Singlespeed
    Last Post: 07-18-2011, 08:28 AM
  5. ti NUke Proof Race SS rigid conversion
    By signalMTB in forum Singlespeed
    Last Post: 04-17-2011, 06:29 PM
