Results 1 to 7 of 7
    New question here. Help on rear hub size
    Hi guys, i am pretty confused what size of rear hub to get. I see there are 10mm, 12mm, 150mm and etc. Is my frame compatible to any of the sizes? Thanks alot.
    Quote Originally Posted by mtnbiker72
    I'm not telepathetic...what is your frame?
    GT Avalanche.
    Former Bike Wrench
    Reputation: mitzikatzi's Avatar
    Easy you need a 12mm by 150mm Hadley Hub
    Only kdding no idea
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    I could tell you, but sheldon brown shows you. Check the chart.
    http://www.sheldonbrown.com/frame-spacing.html
    Jan 2009
    chances are it's a 135mm spacing with a standard axle. i don't think the Avalanche has any of that oversized stuff on it.
    Former Bike Wrench
    Quote Originally Posted by DarkFly3r
    GT Avalanche.
    135mm rear with QR or 10mm through bolt
    100mm front with QR or 9mm through bolt
