    Reputation: mrenteria342's Avatar
    help with my new chain
    im putting together a specialized enduro comp, its a 9 speed shimano deore setup. anyways i bought a 8-9 speed chain. and i dont have the old one.
    stock wise the new chain is to long and has alot of hang, how short
    should i go to get it as a right fit ?
    heres a link to the bikepedia info
    2002 Specialized Enduro Comp FSR - BikePedia
    thanks for the help
    May 2013
    Check out this video @ about 45 seconds they start talking about how to size the chain accordingly. The video shows a road bike, but the concept is the same.
    perfect, thank you very much !!
    Here is the article I used. I went with the simple formula.
    Park Tool Co. ParkTool Blog Chain Length Sizing
    Just be conservative -- you can always take more off. I shortened mine as per the formula, then replaced my 32-tooth ring with a 36, and had to add two links back. It repeatedly broke where I reconnected it, so am running two master links now.
    When you finish, double-check that the rd cage does not rub on the cassette when in the big ring and shifting from the second-biggest to biggest cog.
    Sorry such a long answer to a simple question -- I learned all this the hard way
  1. Replies: 4
    Last Post: 03-14-2013, 05:23 AM
  2. Replies: 10
    Last Post: 08-13-2012, 06:34 PM
  3. Chain skipping- new rear derailer, cable chain and cassette already in place
    By Master Obiwan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2012, 08:06 AM
  4. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  5. I hate Shimano. Chain routing? Breaking the chain? Derailleur adjustment?
    By happyriding in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2011, 01:39 PM
