Results 1 to 20 of 20
    Reputation: Reyeskid's Avatar
    Help My Friends An *******, And It Rained!
    as a part of his prank he stole my bike seat, and it rained last night.... my bike was outside, how bad is this exactly? and how can i fix the damage or prevent it from getting worse...??
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    turn bike upside down....watch water drain out.....
    don't stress about it....mountain bikes get wet...muddy...and overall simply abused....
    (keep it inside for the most part though)
    Click Here for Forum Rules
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    bikes shouldn't be outside in the rain; seat or no seat
    Honestly... ahh I give up
    Dec 2009
    sounds like he kinda did you a favor keeping your seat from getting soaked.
    rides with camera
    Reputation: sherijumper's Avatar
    Feb 2007
    Quote Originally Posted by highdelll
    What he said !
    Fu(k cancer
    thelonebiker.com
    Spice
    Dec 2008
    If you wanna prevent damage the best thing to do it get the seat back, and put it on.
    Unless your into that kinda thing....
    Quote Originally Posted by joehspicer@msn.com
    "Not that there's anything wrong with that" -Seinfeld.
    Reputation: BantamSLK's Avatar
    Once you dump the water out of the frame, make sure you grease up the drivetrain really good, being out in the rain can make a bike rush fast.
    The Race Bike: 2014 Specialized Camber Evo XX1
    pants on head retarded
    Reputation: yurtinus's Avatar
    A bike in the rain is similar wear with or without the seat on it. It's bad for it regardless. Having the seat out doesn't hurt much - many bikes have weep holes to let water drain out anyway. Don't stress it and don't park it outside
    Reputation: Nubster's Avatar
    Is it a steel or aluminum frame? Being out in the rain once wouldn't be any worse than giving your bike a bath. Just make sure it is dry and lube it up just like after bathing. If it is steel there might be some extra precautions to take to protect the inside of the frame.
    Religion = Non-thinking
    Reputation: louisssss's Avatar
    just drain it, lube and grease everything back up and dont leave it outside ever again.
    RH SL Pro
    Newbie
    Feb 2010
    Whats the best lube/grease out there for bikes?
    Quote Originally Posted by GrooveRite
    park blue grease is pretty standard.....and a tube will last 4-evah....
    chain lube is different....depends on the season/conditions/personal pref....
    I've used Prolink gold chain libe and Finishline dry chainlube. i can't tell the difference between the two. in Northeastern wet riding.
    any grease from a bike shop will work and you will not be able to tell the difference. Buy the cheapest tube you can find.
    RH SL Pro
    Newbie
    Feb 2010
    Thanks for the info gentlemen!
    Reputation: Kneescar's Avatar
    Another thing you may want to consider is buying about five cans of sardines and stuffing them inside his seat post 2-3 days before the next hot weather ride. Then never let him near your bike again.
    LCI #1853
    Reputation: PscyclePath's Avatar
    Steel frame? you might take your bike down to the LBS and have them treat it with a can or two of FrameSaver to avoid rust on the inside of the tubes.
    Then take precautions to keep the bike out of undue exposure to the weather. Riding in the mud/wet/rain? the old cavalry adage still works as to what to clean up first: "First the horse, then the saddle, then the man."
    Ride a mountain bike... you will not regret it if you live.
    (with apologies to Mark Twain & The Taming of the Bicycle)
    Professional Speed Bump
    Reputation: captainjoon's Avatar
    Your friend is an *******.
    Quote Originally Posted by PscyclePath
    where did he say it was a steel frame?
    and OP, i would make your friend pay for any damages or repairs you'd need for the bike.
    RH SL Pro
    ~Disc~Golf~
    OP, I'd make your friend build you a garage.
