Results 1 to 10 of 10
    Feb 2013
    Help with my creaking crank!
    During my ride yesterday, my bike developed a very noticeable creaking sound whenever pressure was applied to either pedal of the crank arm. Every pedal stroke it creaks and when I get off and apply direct pressure on either pedal, it creaks as well. This issue just started. I know it has nothing to do with the pedals itself. I have an FSA Afterburner BB30 triple crankset.
    Do I need to tighten the crank arm or bottom bracket? Or perhaps grease the pedal threads? Any help would be appreciated.
    Apr 2013
    I would say your best bet would be to take off the crank arm, look for any deformations, lube the spindle, make sure your bearings arent "crunchy" and lube them up too. re-install, test, hopefully victory.
    Reputation: J.B. Weld's Avatar
    If it's a square taper bb then just torque the crankarm bolts to spec. (tight) before you ride it anymore or you will permanently damage it.
    Feb 2013
    Now both crank arms creak when applying direct pressure or pedaling. What tool(s) do I need to tighten? It looks hexagonal and thus should require something like a really large allen wrench. I'll attach a few pics...
    Feb 2013
    Anyone??
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by Jeremy1983 View Post
    Anyone??
    Have you checked your pivots? Specifically the main pivot right above the BB?
    The fun part about press-fit BBs is that if the BB is creaking, you're in for a troublesome diagnostic session. I'd check the pivots before I went any further, perhaps even going so far as to pull them apart to clean and lube anything you can.
    BB30 = fun times creaking. You can try to grease it, get new bearings, etc and it will eventually come back. There is a special loctite that you are supposed to use that keeps it from creaking. If you do a search with Cannondale and BB30 loctite fixes, the appropriate loctite compound should come up.
    This is all assuming that it is the BB that is creaking however.
    Feb 2013
    The more I'm researching this creaking issue, it appears that it could be a lingering issue with the BB30, and something beyond my mechanical abilities at this time. I could deal with a bit of creaking if that's all it is... just creaking. But if it's indicative of a greater problem, I'll most likely take it in for inspection before another ride. Thoughts?
    If you take it in, they'll probably say you need new bottom bracket. If they install it, make sure they use the proper loctite. I think it is 609? Otherwise the problem will just come up again.
    And heres the BB30 process with loctite.
    How To: BB30 Overhaul/Bearing Replacement | Volagi
  1. Creaking sound coming from crank or rear hub?
    By EZuphill in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2013, 04:55 AM
  2. Creaking from bottom bracket - crank area ?
    By natzx7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2012, 06:27 AM
  3. Creaking Noise In My Crank Set
    By Cabaku in forum Beginner's Corner
    Last Post: 07-02-2011, 09:33 PM
  4. Creaking Sound from crank case? How can I fix it?
    By Big_Carp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 06:14 PM
  5. Creaking in the crank
    By 1SPD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2011, 07:06 AM
