Results 1 to 14 of 14
    Sep 2013
    Help me choose a fork.
    Hey whats up guys. So my friend gave me his old specialized fsr enduro mountain bike just because he wants me to go ridding with him. He took me to some trails and i
    Really enjoyed it. While i was ridding i noticed that the fork was really squishy and it was hard for me to go up the hill because it felt like i was digging into the ground . I was thinking that it might be the fork since its an old rock shox judy. I tried adjusting the rebound but it still feels the same. Can you guys help me choose a new/used fork for around 100 dollars. Or do you guys think im better off just rebuilding the fork for that price.. Im new to mountain biking but i really enjoy it please help.
    Need to know how old. The early Judy's were 1" steerers ,if that true you will have a hard time finding a replacement. There are some replacement parts out there.Check ebay,craig's list for used forks. A local shop might have a take off that would work.
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    I'm not familiar with that fork...does it have lockout? Also, for only $100, you'd be better off rebuilding a fork, or saving up for a good fork. You can also scour eBay and CL...but get ready to part with ~$300 for a decent fork.
    Dec 2012
    try the rock shox dart 2 that locks out.
    Sep 2013
    Thank you for the replies. The size is 1 1/8. And no it dosebt have lock out . Yeah i need something that locksout
    o<o NYC pebble jumper!
    Reputation: skene's Avatar
    May 2013
    Best bet would be Ebay...
    If you knew if you needed a tapered head or straight it would probably be better to know so that you also do not waste time on finding a fork that would fit your bike within your budget.
    My little friends
    Reputation: EABiker's Avatar
    Actually, you don't really "need" a lockout. A decent quality air fork and a bit more experience on the climbs will overcome the pedal induced bobbing you get on the fork. Smooth pedaling, rather than just mashing, helps keep the wasted energy to a minimum.
    Fat-tired Roadie
    Nov 2007
    The Judy was available in a few different springs at different times. Also, the rebound damper's not really the right adjustment to stiffen up the fork's response to rider input.
    IIRC, it's been a coil, an air, and an elastomer fork at different times. Can you post a picture of the fork crown? Take one of the front end of the bike too. This could be as simple as learning to tune the fork you've already got.
    IMO, no worthwhile suspension forks retail for $100. However, if your fork is damaged or no longer has available maintenance parts, you might find something on EBay.
    Reputation: traffic002's Avatar
    Dec 2008
    Look for a Rockshox Tora U-turn fork.
    It's probably the best budget entry level fork at about $200. Anything less than that really isn't worth your time IMHO.
    Just get out and ride!
    Reputation: Shakester's Avatar
    Jun 2012
    Sounds like a 2000-2002 Specialized. You have plenty of options, but I wouldn't overdue it. I agree with the above and Tora is a nice way to go. I see some on Ebay for $150. Even an old RS Recon would work nicely. If you're not running disc brakes, then you may want to make sure the fork has v brake post mounts.
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    Great advice all around. I have nothing to add. Hate it when that happens.
    Jul 2013
    +1 on the rock shox recon! I just picked one up and i love it. Great fork. Heres the thread if you care to look
    Fellow newbs, it can be done! DIY fork install upgrade
    Sep 2013
    This the fork it is a rock shox judy xc the steerer tube messures 7 1/2
    Fat-tired Roadie
    Nov 2007
    A shiny new fork will at least fit on your bike. You need to decide what to do about brakes. Travel is probably about 100 mm, steer tube needs to be straight gauge.
  1. Choose a fork for me
    By HrznRider in forum 27.5
    Last Post: 08-30-2013, 06:10 AM
  2. Help me choose a fork
    By Buzzaro in forum California - Norcal
    Last Post: 04-04-2013, 08:42 AM
  3. Help me choose a fork
    By Buzzaro in forum Shocks and Suspension
    Last Post: 03-28-2013, 09:20 PM
  4. 575 needs new fork help me choose!
    By yeti575inCA in forum Yeti
    Last Post: 10-19-2012, 01:08 PM
  5. How do you choose the rigid fork?
    By vemeno in forum Singlespeed
    Last Post: 03-15-2011, 03:20 AM
