Results 1 to 8 of 8
    Reputation: RoosterBoy's Avatar
    Smile Help fix my bike problem please
    hi i was wondering if by looking at my specs can you tell me what to do to make my jamis feel more like the rock hopper. what could i change and change to without buying the rockhopper i feel to stretched out on my jamis and my neck gets sore.
    here are the specs on both jamis and rockhopper eaven a kona felt better. my jamis durango is a 19 inch
    What size is the Rockhopper in question? First place to start would be a shorter stem and/or moving the seat forward. Maybe try a riser handlebar as well.
    Smile
    the rockhopper was a 19 inch also. id like to get my jamis 19 inch to feel like the rockhopper.
    my neck will thank me for it.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Shorten the stem reach, maybe add some rise, slide seat forward on it's rails. If that still doesn't do it then it's time to change bikes.
    Former Bike Wrench
    Well, looking up the geometry of the Jamis...its not that much different from the Rockhopper. I did notice that a 19" Jamis uses a 120mm stem. This seems long to me, and I'd be willing to bet that the Rockhopper is using a shorter stem (something like a 100mm maybe?). So as suggested above, start by using a shorter stem.
    not your average bear
    May 2005
    The caveat with going to a shorter stem, is the bars may now feel too narrow. The suggestions above about shorter stem _combined_ with riser bars is a good one. Riser bars are sold as wider than flat bars--this would solve roosterboy's probs.
    Smile
    thanks guys makes good sense i tried finding the same type of handlebars and stem online
    here is the rock hoppers specs
    STEM Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise
    HANDLEBARS Alloy 31.8mm XC rise, 640mm wide, 8 degree back, 6 degree up sweep, 3.0mm thick
    i cant seem to find a perfect match with the online stores but maybe i will try a 90mm stem and 8deg riser bar that's 640mm wide.
    thanks
    Jason
    Newbie Rider
    I know it is cheaper to shop online, but you should really go get a few of your components at your Local Bike Shop and they would probably help fit your bike to you pretty cheap.
    Your problem is probably less related to your parts and more to your cockpit setup. A good bike shop will know exactly how to set you up and could save you a lot of time and $$'s switching out components.
