Results 1 to 5 of 5
    Help Diagnosing Drivetrain Issue
    About halfway into a ride on pretty standard Northeast singletrack (roots everywhere) yesterday my rear derailleur was delaying when I shifted gears. I'd hit the shift lever and then it would click a couple times before shifting (a delay of maybe 3 seconds). By the end of the ride I was slipping gears and it seemed like I was shifting at random times. Any clue on the origin of the problem? Worn chain, broken derailleur, bent hanger?
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Age of bike? Crashed lately? Lots of variables that'll affect shifting. Probably not the chain...they usually don't go bad during a single ride. A derailleur alignment gauge is a good investment and the hanger is usually the first thing I check when I have shifting issues. Try adjusting the ferrules on your shifter cables a little at a time...1/4 turn at a time. Try one way and if it gets worse go the other way.
    The bike is 2 years old. No big crashes lately but it's slid out from under me a couple times. The chain hasn't been replaced nor the derailleur adjusted since the bike was assembled.
    Enthusiast
    Reputation: JonathanGennick's Avatar
    When shifting goes bad suddenly, it's often the hanger. Possibly it got bent slightly one of those times the bike slid out from under you. It might not even be enough bend to see. It doesn't take much to throw off the alignment, and hence the shifting.
    El Gato Malo
    Could be a number of things, here's a good resource:
    Tech Tips
