Results 1 to 13 of 13
    Help! Brake Rubbing problems
    Hi all,
    I have recently upgraded to BB7's apart from the initial set up I haven't had to touch them, as firstly I haven't ridden much and secondly they haven't had any issues.
    I have now noticed that the brakes are rubbing and no matter how I try to move, adjust or just fiddle with the caliper, the thing is still rubbing on the bads and also one of the mounting bolts.
    The root of this issue I believe can be found in the fork, hub or QR.
    The wheel does not sit in the fork centre (yet I have no tracking or handling issues) and the wheel seems to have something wrong in the hub/QR area as the wheel doesn't track straight (it wobbles as if warped).
    Has anyone else had this issue and what needs to be replaced/repaired to fix it? I ride it almost every day as a commuter as well as off road so it needs to be running.
    I believe it personally to be the QR, would this cause the issues?
    I don't know much about QR's but to replace I'd presume I'd get a DT Swiss or Shimano set up, is that correct?
    Thanks and I hope someone can help.
    does the hub feel loose?? if it's a shimano hub it uses a cup and cone if the nuts that sandwich them together get loose the wheel will wobble. If the wheel seats properly in the dropouts but looks bent you may just need to have the rim TRUED at your LBS.
    <img src="http://cdn.mos.bikeradar.com/images/bikes-and-gear/components/WMB88.work.work_pic12_prev-499-100-499-70.jpg" />
    The bike is a 2006 Specialized Hardrock Sport Disc.
    The hub has very little play, I have checked with the wheel and the QR for play in it.
    I believe something is bent causing the wheel to sit wrong, where and what is what I don't know.
    The hub setup: "Joy-Tech, disc, 36h, ground race double sealed loose ball w/ alloy QR"
    Could it be the QR or hub with the issue? Or is it the setup of the brakes?
    I'll update with videos of what its doing and the parts in motion tomorrow, but if anyone has any idea I'd like to know possibilities.
    Thanks for your help!
    And if not, to my LBS it goes
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Did you adjust the fixed pad adjuster when you tried to adjust the caliper position? I would have to guess that you probably tried to recenter the caliper but the fixed pad has worn down a bit leaving your caliper centered around the pads but not the caliper.
    Try dialing the fixed pad adjuster in so that the rotor is centered in the caliper but just barely not rubbing when you get it tightened down.
    Unless you have play in the system when the QR is tight then you shouldn't be having a hub issue. Actually, make sure that your wheel sits straight in the dropouts; if it's canted to one side that could also cause your issue. Loosen your QR, let the wheel center in the drops and carefully tighten the QR back down.
    Fat-tired Roadie
    Nov 2007
    "Very little play" is too much, at least when the wheel is mounted and the quick release is tightened.
    I've had trouble adjusting non-Shimano cup and cone bearings to their happy place, with no play when mounted and also spinning nicely. But, it's worth a shot.
    http://www.parktool.com/blog/repair-...and-adjustment
    @zebrahum I've adjusted the pads in and out, checking through the hole that's shows alignment, and it still rubs. It could be that I'm not clued in on all the possibilities on adjustments (Avid instructions are terrible) but I've fiddled with pads, where it sits on the adapter, where the adapter goes onto the fork etc and it's still rubbing.
    @AndrwSwitch I shall take the hub apart on the weekend then and see what's the story in there, after I play with the adjustment some more. Thanks for the helpful link, it will definately help me out. The play in the hub is barely a mm of movement, I couldn't see how that makes the wheel sit wrong in the forks?
    Did you adjust where the caliper bolts into the adapter? If not, up screw both adjusting bolts on the caliper (ones that adjust the pads) then loosen the caliper bolts (the ones that screw into the adapter that connects to your fork) and get it dead on straight, tighten and then adjust the pad adjustment knobs.
    Yeah well it made it to work today but I now have an issue with my derailer. I'll get my LBS to look it up.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by Specialized03 View Post
    If they're a nice shop you can ask them to explain what they're doing as they work on it so you know what to do or look for in the future.
    Take Chances
    Reputation: tymelero's Avatar
    Here are some good articles regarding adjusting. Not sure if there are other problems but these really helped me with getting the avid breaks working right.
    http://www.parktool.com/blog/repair-...isc-adjustment
    http://bluecollarmtb.com/2006/10/30/...l-disc-brakes/
    (not bb7 but similar)
    I like turtles
    Reputation: TiGeo's Avatar
    Okay, may sound obvious, but are you sure your front wheel is fully and squarely seated in the drop outs? I ride with a new that can't ever seem to get his front wheel in right! Sounds like if it isn't obvious a simple trip the bike shop will guarantee a positive result!
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Thanks everyone, especially for the adjusting website.
    @TiGeo don't worry, I checked that before going to the trouble of making a thread. Thanks though!
  1. 2009 Sultan front derailleur cable hose rubbing problems
    By Midle Age Warrior in forum Turner
    Last Post: 07-13-2011, 09:06 AM
  2. Front deraileur chain rubbing problems.
    By Judoflip in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2010, 06:46 PM
  3. rubbing problems in middle chainring
    By kkeith1986 in forum All Mountain
    Last Post: 04-03-2008, 07:13 PM
  4. Brake rubbing
    By rangehunter in forum Tooltime
    Last Post: 07-03-2007, 08:21 AM
  5. Bontrager Select Cranks-XT FD; shifting rubbing problems...
    By bcaronongan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2007, 06:36 AM
