Results 1 to 12 of 12
Thread: Heavy Hands
    Jun 2013
    Heavy Hands
    Hi, I'm pretty new to mtb and it's been about 2 months since I've bought my first real bike.
    I have read some tips about keeping your hands light when riding for better control of the bike and have been trying to get the hang of it.
    My problem is that I seem to have a hard time keeping my hands unweighted when riding along on a flat surface. I have noticed that if instead of grasping my handlebars with my palm and add just an inch or two to my reach with my knuckles it becomes much easier to keep my hands light. (leaning back slightly)
    Should I be looking for a solution to this in some form of adjustment on my bike or is it more likely my technique that needs work? both?
    Reputation: Gasp4Air's Avatar
    It sounds like you would benefit from a longer cockpit - that is, the distance from your saddle to your bars. There are different ways to accomplish this.
    Move your saddle back. If it's back all the way, an offset seat post can add up to an inch of rearward movement.
    Get a longer stem for your handlebar.
    Try rotating your bars forward a bit. You can only do this so much before the angle of the grips is no good.
    Also, look at the angle of your saddle. If it's nose down, it will tend to slide you into your bars.
    Experiment with the least expensive options first.
    Use it, use it, use it while you still have it.
    Apr 2013
    heavy feet light hands.
    A recommended read
    https://play.google.com/store/books/...d=_2wkch1SE3QC
    You need a shorter stem not longer. You can see this by what happens when you change how you grip. With a shorter stem you could have your normal grip with you leaning back slightly.
    But you also need to be able to weight your front tire for traction in curves. It's a matter of balance.
    Quote Originally Posted by eb1888 View Post
    Yup, I think I got that backwards. Just reverse everything I said.
    Jan 2013
    Quote Originally Posted by Gotphill View Post
    A recommended read
    Great read! Nice tips that could really help..
    Jun 2013
    Thanks for the tips everyone
    I'm going to try and start with moving my seat forward slightly before I make a purchase of a new stem.
    Usually there's a box of used stems at your lbs with the service guys for trying out.
    Reputation: Burt4x4's Avatar
    Feb 2013
    WHat about adding a riser bar? Is your current handelbar "flat"?
    I too am searching answers to this topic...
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Jun 2013
    I just moved my seat forward 3/8" to 1/2" and tried to make an effort to sit a little straighter. Been doing it for about a week and it seems OK so far. We'll see if the back starts hurting later on, but so far so good.
    Feb 2013
    Is your handelbar flat or raised?
    Jun 2013
    No, they are pretty flat. I have a Trek Mamba '13 (picture for reference)
  1. How heavy is a "heavy" 29er frame ?
    By manmythlegend in forum Weight Weenies
    Last Post: 07-10-2013, 01:14 PM
  2. Need help for my hands
    By Thumpy69 in forum General Discussion
    Last Post: 03-27-2013, 05:03 AM
  3. Big Hands Big Grips
    By vcyclist in forum 29er Components
    Last Post: 03-06-2013, 08:50 AM
  4. Numb hands...why?
    By hokie rdr in forum Bike and Frame discussion
    Last Post: 08-16-2011, 02:56 PM
  5. I might be getting my hands on an M9...
    By dans160 in forum Intense
    Last Post: 08-11-2011, 06:31 AM
