Results 1 to 3 of 3
    Reputation: doc Dee's Avatar
    Aug 2010
    headsets & stems
    is there a big difference in upgrading headsets and stems? benefits?
    thanks in advance
    Former Bike Wrench
    Headsets-going to a good cartridge bearing unit can save a little weight and make it a set and forget item. Spending a lot of money beyond that is mostly a "Bling" expense.
    Stems-there is very little performance gain from a $20 to a $100 stem, some weight loss and/or strength gain. Again most of the high cost is bling factor.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    No and Maybe....
    Quote Originally Posted by doc Dee View Post
    thanks in advance
    A headset is basically a set of ball bearings that allow you to turn your handle bars. Unless your headset bearings are shot, you're not going to see much difference between one headset and another as an arbitrary upgrade.
    Stems: Depending on the type of stem and how you ride, you may see an improvement in comfort, flexing and the general fit of the bike. It really depends on you and whether you're having problems.
    If you're asking based on upgrading in general, I'd look at upgrading almost everything else before upgrading the headset. I'd upgrade the seat post and bars before the stem, unless there was a specific problem I was trying to solve.
    JPark - 3.5- don't listen to dremer
  1. Shortest stack Headsets & Stems
    By scarbelly in forum Bike and Frame discussion
    Last Post: 11-01-2007, 06:26 PM
  2. measuring headsets, stems, bottom brackets etc...
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 05-02-2007, 04:06 PM
  3. short stems, long stems -- whats the difference
    By BruisedKnee in forum Beginner's Corner
    Last Post: 11-22-2006, 11:53 PM
  4. Stan's UST Stems vs. Mavic UST Stems?
    By myitch in forum Wheels and Tires
    Last Post: 02-02-2006, 12:03 AM
  5. MTB Stems $4 / SYNCROS Stems $19
    By PSYLO69 in forum Ritchey Design
    Last Post: 03-19-2005, 07:04 PM
