Results 1 to 10 of 10
    Gx4
    Gx4 is offline
    Oct 2013
    New question here. Headset question for on-one whippet
    Hi All,
    I've been riding for around ten years with an old Corrotec x-vert and decided to treat myself a new MTB with SLX groupset.
    Recently I bought on-one whippet with integrated headset, so I dropped in the cups and expected the best. My first build
    It says it is 1 1/8.
    The problem is that bottom is much wider and does not sit on fork crown race but on the fork itself.
    fork image
    Does anyone know what my problem is? Is it for tapered forks or do I need a headset reducer or a special crown race?
    p.s. also I bought kcnc 92mm bottom bracket and took the BB and the frame to my LBS and surprise surprise they said the BB is standard shimano 73mm "screw in". So the plastic BB that comes with SLX crank fit right in.
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    Its for a tapered fork, you can get a headset that can use a regular fork
    Sent from my Transformer TF101 using Tapatalk 4
    I think there is a misunderstanding with your LBS. The Whippet uses a BB92 bottom bracket. If they used a plastic BB, that's a BB92 bottom bracket. External threaded BB's are not plastic.
    Your picture doesn't work. What headset did you buy?
    Gx4
    Gx4 is offline
    Oct 2013
    Fork image, maybe this works:
    I ordered now : Da Bomb Depth Charge Headset - 1.5" Reducer 2013 | Chain Reaction Cycles
    Also, for the BB I had Product KCNC BB92 Pressfit Bottom Bracket and it did not fit. And the one that came with SLX is Bike24 - Shimano SM-BB70 Bottom Bracket BSA for Hollowtech II
    Aug 2013
    Is it a BB30?
    Sent from my EVO using Tapatalk 4
    You sure it's a Whippet? I think you need to talk to OnOne.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Gx4 View Post
    You have Carbon 456, not a Whippet.
    The headset you linked is wrong for either frame.
    mtbtires.com
    Gx4
    Gx4 is offline
    Oct 2013
    Quote Originally Posted by shiggy View Post
    Yes, you are right. It is 456.
    I am sure I ordered yellow undecaled whippet (at least that was written on the invoice) and tadada it's not.
    But the shipping costs are too high to return. So I'll probably order On-One Smoothie mixer.
    Reputation: Nakedbabytoes's Avatar
    If it was ordered wrong by the shop, why would you have to pay return ship?
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Gx4
    Gx4 is offline
    Oct 2013
    Quote Originally Posted by Nakedbabytoes View Post
    Maybe not, but I already threw the boxes away since they take too much space to keep, so my bad. Also, the process is a hassle for me.
    I just want to ride it.
    If I'm only missing the headset it's faster for me to get that than to get the frame exchanged. Also, the 456 and whippet is not that different (at least for me) and if I get new longer fork for drops the 456 suits even better.
    I contacted On One and will see what their answer is.
  1. Whippet question!
    By Ltdan12a in forum On One
    Last Post: 08-23-2013, 10:15 PM
  2. Replies: 7
    Last Post: 08-02-2013, 08:29 AM
  3. FSA the Pig headset question....
    By jc1surf in forum General Discussion
    Last Post: 06-23-2013, 03:15 PM
  4. Headset Fit Question
    By foxtrot in forum Tooltime
    Last Post: 02-04-2011, 09:02 AM
  5. Headset question
    By p nut in forum Shocks and Suspension
    Last Post: 01-22-2011, 02:08 PM
