    Headset assembly
    Hi ,
    This is my first bike build so i guess this is the right forum for me. I'm putting in an FSA pig headset. On the upper cup , does the bearing ring go into the cup cage side first or with the cage facing up ?
    I put it in cage up already but thought about it and this does not seem right , so just to confirm with someone who knows.
    http://www.parktool.com/repair/readhowto.asp?id=65
    that should answer your questions.
    Reputation: matt1976's Avatar
    Or:
    Bearing side UP
    Retainer side Down
    Straight from the FSA Pig Headset installation manual. Didn't you get one?
    Hope that helps.
    Matt
    I'm here for the OT
    Thanks for replying fellas , i did'nt get a manual with the headset. I guess they dont ship 'em that way over here.
    I figured it out but now i'm not sure because my headset only works the other way around. When i tried to install it retainer side down the steering was totally stiff when i "preloaded" the bearings by tightening top nut a little bit whereas with retainer up my steering works perfectly . Whats up with that ?
    When ya think about it it makes sense , the steering needs to roll around in the cup , no ?
