Results 1 to 3 of 3
Thread: Headset
    Cheesiest
    Reputation: intheways's Avatar
    Headset
    As a general question, what are the consequences (to the headset) of overtightening a starnut?
    Does it just wear out quicker?
    "El Whatever"
    Reputation: Warp's Avatar
    Yup...
    and your steering goes harder... you can damage the bearings as well... I had been there, had done that.
    Go to a wall. As you tighten the starnut, push the bike fore and check for movement at the headset. When you get no more play, stop there. The minimum force required to avoid play in the headset is the maximum you hsould apply to the star nut. Now just tighten the stem bolts and you're done.
    Check my Site
    Old man on a bike
    You should tighten the starnut bolt
    enough to make sure the stack (of bearings/spacers) is tight, but not tight enough to bind the bearings (the bars should rotate freely). You can somewhat over-tighten the starnut bolt first, check for play in the headset, then tighten the stem bolts, then back off on the starnut bolt a bit as the work of holding the stack together is now being done by the stem bolts, at least this is how I do it. I think a lot of stems recommend around 40 in/lbs of torque on the starnut bolt, whereas the stem bolts are usually 80-90 in/lbs, to give an idea of the ratio between the two types of bolts...hope that helps.
    suum quique
  1. Opinions on greasing headset cups
    By Lab Worker in forum Tooltime
    Last Post: 06-14-2004, 07:28 PM
  2. How to change an intergrated headset for a regular?
    By BanzaiRider in forum General Discussion
    Last Post: 05-19-2004, 10:06 PM
  3. Extralite Integrhead headset....
    By atbcrash in forum Weight Weenies
    Last Post: 05-05-2004, 12:12 PM
  4. Upgrade for integrated headset?
    By CalPolyClimber in forum General Discussion
    Last Post: 02-18-2004, 03:53 PM
  5. help...headset cup loose
    By erol in forum Singlespeed
    Last Post: 01-18-2004, 07:04 PM
