Results 1 to 3 of 3
    Hardrock Sport handlebar quality..upgrade?
    I recently decided to come out of a 26 yr. retirement from BMX racing and get back into biking again @ age 42. After some brief research and limited budget I just purchase an '08 Hardrock Sport and I love it! I haven't done much dirt/trail riding yet but I definitely plan on hitting trails, jumps etc. Anyhoo... I don't feel the need to do any major upgrades at this point but I'm thinking maybe a bit wider/higher on the bars would be more my style. I don't want to spend too much money or end up with something inferior to the stock bars but I have no idea of the quality/cost of them either:
    STEM Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
    HANDLEBARS Alloy 25.4mm, 640mm wide, 38mm rise, 8 degree back, 6 degree up sweep, 3.2mm thick
    Can anyone recommend an inexpensive upgrade? Should I also replace the stem?
    Is something like this even worth considering?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=024
    TIA
    P.S. How do I measure stem length on the stock stem? end-end? Center-Center?
    J
    With those bars you will need to replace your stem to a 31.8 diameter. I got the same bike and put a 31.8 Specialized comp stem and enduro bars to beef it up some. Good luck.
    sweet!
    Reputation: Diamondhead's Avatar
    Nov 2007
    All my riding buddies and I recomend Titec Hellbent Gold, strong, light and bent just right 8 deg. back sweep, and 4 deg. up sweep.
    http://www.titec.com/pdmain.php?class=1&series=2
    Stem length is measured from the center of the steer tube clamp to the center of the handlebar clamp.
    The 24.5 mm denotes the dia.of the handlebar clamp.
    Good luck!
    "It's a Sledgehamer" "Dang! You got shocks, pegs...lucky! " Napoleon Dynamite & Pedro Sanchez
