Results 1 to 19 of 19
    Aug 2010
    Hand position when climbing
    While I was climbing a rather steep uphill today, instead of wrapping my thumbs around the grips I laid my thumbs horizontally on the top part of the handlebars, and I could've sworn the climb felt a little easier. Anyone else have experience with this?
    Granny gear lover
    Fat-tired Roadie
    Nov 2007
    Do it all the time.
    There's nothing intrinsically easier about it, IMO. Just do whatever works for you. You probably gave yourself a little extra room to get a little lower over the bike - a physically more powerful position for most of us when we're really working it.
    I've noticed that before as well, but I couldn't tell if it was actually easier or if it just felt easier because it was something new/different. For the time being I'm just going to agree with AndrwSwitch.
    Aug 2010
    Quote Originally Posted by AndrwSwitch View Post
    Do it all the time.
    You're right. I noticed that I was able to get my face lower towards the handlebar, and also that it was easier to pull the handles back towards me. That's what probably made it feel easier.
    Granny gear lover
    Aug 2010
    I've been using this technique for the last several rides, and now there's a loud squeaky noise coming from the front of my bike whenever I climb
    Granny gear lover
    Fat-tired Roadie
    Nov 2007
    Bummer.
    That could be a lot of things - headset, one of the stem clamps, fork, hub. Try to make it happen when you're off the bike, so you can narrow it down.
    Reputation: Bilirubin's Avatar
    Quote Originally Posted by John K. View Post
    Check the rider first
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    I'd start with...
    I'd start with check the parts that receive more torque while climbing:
    Stem: Handlebar and steerer tube interfaces. You can test this by moving one of your hands inside your shifter/brake on the handlebar and your other hand on the head tube. Be careful.
    Seat: rocking on your seat may be causing the creak. The test for this is to come off your seat while climbing to see if the creak goes away.
    From there, it could be a number of different creaks based on the type of bike you ride.
    Creaks will drive you nuts. I have one that I'm trying to track down. It just takes a while to isolate the cause.
    JPark - 3.5- don't listen to dremer
    Hold your front brake and rock the bike forward and back slightly. There should be no play, if there is the headset needs adjusting. Even the slightest bit of play can cause all kinds of creaking noises.
    Sent from my DROIDX using Tapatalk
    Aug 2010
    Truth is I've been yanking back on my handlebars as I've climbed, but I didn't think that this would knock anything loose. Guess I shouldn't do that anymore and focus more on my legs, or at least not yank as hard.
    Granny gear lover
    Fat-tired Roadie
    Nov 2007
    Hauling on the handlebars is not necessarily bad. That's what they're there for. Just try not to have it be wasted effort.
    Mar 2013
    This is something that I have been doing for a little while now. If I remember correctly I read it in MBA. Part of the reason the climb feels easier is because by putting your thumbs on top of the bars your "relaxing" your grip. So there's not as much "wasted" energy.
    I have for me, it allows me to focus more on my cadence. It also feels alot more natural/comfortable to me now. I have noticed that some of my climbs have actually gotten faster (though they are still slow compared to some of the guys that I ride with).
    Moderator Moderator
    You should be able to yank on your bars as hard as you can endlessly without an issue. If you are getting anything to move by doing this, something's not adjusted/installed/manufactured correctly.
    Shaman
    Hey guys, I love where H6NVGce is headed with this thread. Tension creates using unnecessary energy. You should be able to wiggle your fingers when climbing trail that is not super techy.
    Weight should be centered over the bottom bracket. Once the terrain gets steeper, the center of gravity changes and your body needs to adjust in order to stay balanced over it. By scooting forward on your seat and bending your elbows you can maintain a relaxed yet efficient body position for climbing.
    Skills coaching loved by passionate riders of all levels and trusted by the pros.
    www.betterride.net
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    I usually cradle the bar end lock-on caps, simulating I have bar ends and that works good too. Nobody needs a crazy, firm grip(or bakes) climbing.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Mar 2013
    Duplicate post...
    Reputation: Jams_805's Avatar
    Aug 2013
    I also do this when I climb, but I also find myself doing it when im getting tired.. and im sure one day it will lead to me face down in the dirt. Im trying to make sure I only do it during climbs
    Rockhopper 29er
    -FSA Carbon handlebars, stem, & seatpost
    -2011 Rockshox Reba
    -Stan's Flow Wheelset
    -Ergon Grips
    Mar 2013
    Anyone with input please chime in-
    Another thing that I have noticed here recently is that when I put my thumbs over the bar, my shoulders neck and back feel more relaxed. I have also started paying more attention to my breathing. I have started to forcefully exhale 2 or 3 times immediately before the climb. I ve been told that it helps to get fresh oxygen in, and old oxygen out. I can say that it has seemed to also help on alot of the climbs that I have been having trouble with. It seems like this "technique" has helped me to get farther up the climbs then previously before I run out of breath.
    2012 Specialized Hardrock Sport 29
    2014 Specialized Stumpjumper Elite
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Relieving hand pressure by placing them on top of the bars and relaxing them shifts the work to your core, where it should be. I do it all the time just for that reason. It helps a lot with building core strength.
  1. hand position while downhilling
    By ezl_oo in forum Downhill - Freeride
    Last Post: 08-11-2009, 10:10 PM
  2. Can't get comfortable hand position with riser bar
    By beanbag in forum General Discussion
    Last Post: 05-17-2009, 12:22 PM
  3. Bar Sweep and arm/wrist/hand position
    By Ptor in forum 29er Bikes
    Last Post: 01-22-2008, 01:38 PM
  4. Hand Position vs Shorter Stems
    By Blue Shorts in forum Turner
    Last Post: 07-12-2007, 06:18 PM
  5. hand position when hucking???
    By tinystyle in forum Downhill - Freeride
    Last Post: 04-05-2004, 12:16 PM
