Results 1 to 7 of 7
    Had a package waiting for me when I got home.
    My first set of clipless pedals came today.
    Can't try them cause the shoes aren't here yet. Hopefully they come in tomorrow or the next day at the latest. I'm excited.
    Awesome..enjoy em. My first pair that I just started on were also Time's (the ROC ATAC version) There great!
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Sweet! I would have opted for the pedal wrench with the chain whip on the other side for home use, but again Sweet!!
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    Reputation: SwampDonkeyDisco's Avatar
    Sweet! It helps to put the binding tension on the lowest setting when you are starting out...also, ride the bike on grass at a park ....if you are anything like me, you will fall once the first day.
    Reputation: Nubster's Avatar
    I have the same pedals and they are awesome. A little heavy but they are tanks. I am using the carbon versions on my new bike I am building this summer.
    Quote Originally Posted by SwampDonkeyDisco
    I checked that, apparently they're set to the lightest position so I should be good to go.
    I just serviced mine today and I suggest you do the same so they never squeak. The whole process shouldn't take you more than 5 minutes.
    Hold two small screw drivers across from each other and use the circular holes to unthread the plastic cap. Unthread the silver nut. Use a socket or punch and lightly bang the threaded end with a hammer to remove the spindle from the body. Apply lots of water proof grease where the spindle meets the body. Reassemble. Enjoy your new, great squeak free pedals.
