Results 1 to 9 of 9
    Nov 2012
    New question here. Which grease to use for front head bearings?
    Hi had creaking while compressing my fork, while climbing and whenever i put weight on the front of the bike. So I greased the bearings in the head tube and the creaking stopper. It's started again after a couple of hour on the first ride since servicing. I think the grease might not have been tough enough because grease was coming out a little at the bottom of the head. It was a really hot day and intense climbing. I used syntethic all purpose grease! What grease should I use? I will also look for cracks!
    By the way my bike is a specialized enduro comp XL 2012. And I'm a 230 pounds athletic guys! Might I be too heavy for the frame? I don't think so but i ask!
    Thanx
    Nov 2012
    I also saw i little rust or wear inside the the head where the bottom bearing sit. I was also noticeable on the bearing itself. All located in the back or at 6 o'clock.
    Pretty well any grease will work. The synthetic you used will be fine.
    Jan 2013
    Quote Originally Posted by Welric View Post
    Just use any grease available out there, you should be fine...
    Fat-tired Roadie
    Nov 2007
    I've typically used fancy grease marketed for bikes. Supposedly, it's just marine grease in smaller bottles with a bigger markup. I'd try that if I bought enough of it for the price to bother me.
    There's more than just grease to getting a nice, quiet headset - it needs to be adjusted correctly.
    Park Tool Co. ParkTool Blog Threadless Headset Service
    How old is the bike? With some styles of headset, taking a little time to do a proper rebuild can be helpful.
    Nov 2012
    Ok but If the grease i use was suppose to be fine why did it start creaking again! The bike is a 2012 and a couple months old, but has been used as demo bike in a shop!
    Nov 2012
    I'm also worried a little about the little wear on the bearing and frame! I might put a picture
    Reputation: shiggy's Avatar
    Dec 1998
    Likely because the headset is not adjusted properly, as mentioned earlier.
    Pics are not needed.
    mtbtires.com
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    Been using Lithium automotive bearing grease for my hub servicing every 500-1000km and so far it worked quie well. And I ride whatever nature throws at me. Snow, mud, dust and sand... makes very little difference. Overal it's much better than the original thick gunk that was in there.
  1. 29er Element ABC Bearings - Grease
    By bonesetter2004 in forum Rocky Mountain
    Last Post: 11-07-2012, 04:03 AM
  2. How Often Grease Wheel Bearings?
    By stumpbumper in forum Wheels and Tires
    Last Post: 08-06-2012, 06:10 PM
  3. Replies: 1
    Last Post: 08-05-2012, 01:42 PM
  4. Grease for cup-n-cone hub bearings?
    By mkrause in forum Tooltime
    Last Post: 03-02-2012, 07:05 PM
  5. T2 when & how to grease bearings
    By Pure in forum Intense
    Last Post: 10-04-2011, 10:11 PM
