Results 1 to 8 of 8
    Life is Short...Ride Hard
    Reputation: LvilleFan's Avatar
    got a flat, how about a tube eh!
    So I got my first flat since I started riding. I feel like a real mountain bike rider now
    Luckily I made it back to the car. It actually wasnt till I pulled the bike out of the garage to go for another ride that I realized I even had a flat. It was empty of air.
    Anyhow, I need to buy some tubes and patch kits. So Whats the differences between tubes? Do I need to spend a lot on tubes or can I just use cheap tubes?
    There are differences in tubes ,heavy duty, lite weight ,preinstalled slime. In general buy what's onsale. Or go to tubeless,I've worn out tires running tubeless with no flats.
    Quote Originally Posted by LvilleFan View Post
    http://www.notubes.com/Stans-Tubeless-Kits-C12.aspx
    Ya see above. LBS I picked up my Trance from did the conversion for me for free, I just had to buy a bottle for like $12 or however much it was. Pull crazy thorns out of my tires after each ride and stans just seals it up
    I went through a few trail flats which is especially crappy in the AZ summers until I decided to switch over. Wish I did it before I even took the bike out of the shop now
    Fat-tired Roadie
    Nov 2007
    I did generic tubes for a long time.
    Recently I got some ultralight tubes. Still the butyl rubber kind - nothing really weird. I didn't pay anywhere close to retail, for the sake of disclosure and the TOU. I was too lazy to be scientific about comparing the old and new tubes, and did 'em at the same time as some new tires. But the lighter tubes and tires do handle quicker. So, at least on bikes I compete on and if I'm ordering at the right time to get my team discount, I'm going to be getting lightweight tubes in future. No downsides, so far.
    I recently purchased four Continental 29er tubes.
    I compared the Continental 29er tubes to the Cheng Shin tubes which came stock on the bike and found the following:
    > The Continental 29er tube and the Cheng Shin tubes are both made in Taiwan.
    > Both tubes had identical manufacturing molding marks, seams, and molded expansion panels.
    > The only differences were a slightly different set of numbers printed on the rubber base of the valve stem, a different color valve cap, and a slightly higher price for the Continentals.
    I searched for 29er Continental tubes manufactured in Europe, but was told that only some of the 26" tubes are made in Europe, and all their 29er tubes are made in Taiwan.
    I bought a used bike from someone and it had slimes. it worked the first time when i ran over a thorn but after a while the slime seems to clog up the valve. I replaced them with maxxis ultralight which weigh in at 125g and I put on mr tuffy tire liner for more protection. 2 months so far no flats. With the ultralights and tire liner it weighs about the same as a standard tube but I have better protection.
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Take it up a notch and change the tube on the mountain!
    Then you'll be a mountain biker! Lol
    I run Slime Lites... Never had any problems with them.
    I ride a lot of rock gardens and see people running tubless blow the tire off the bead... So no tubeless for me!
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
  1. After flat, reuse tire and tube?
    By egocycle in forum Wheels and Tires
    Last Post: 04-24-2011, 12:55 PM
  2. Super Inner Tube = No more more Flat Tires
    By johnnycrash in forum Wheels and Tires
    Last Post: 01-30-2011, 05:51 PM
  3. Got a tube flat from tire liner
    By Mtn-Rider in forum Wheels and Tires
    Last Post: 08-29-2010, 07:04 PM
  4. Had a flat, used 26 inch tube
    By tmccrohon in forum 29er Bikes
    Last Post: 08-13-2010, 12:22 PM
  5. Got a flat tire......thanks for the tube.
    By surfandrescue in forum California - Socal
    Last Post: 06-15-2010, 07:13 AM
