Results 1 to 3 of 3
    May 2012
    Good tutorial on calibrating/fixing my brakes?
    I have disc brakes, and lately, I've had to press the brake lever almost to the end before I feel the brake actually working.
    I"m a beginner, so I'm looking for an easy-to-follow tutorial/video that explains how to calibrate these brakes, or change them if necessary.
    Total Goober
    Depends on the brand and model. Are they hydraulic? Youtube probably has vids. I would use the search terms "how to adjust xxxx brakes" and "change pads on xxxx brakes". They might also need a bleed if they are hydraulic, but I would check the pads first.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    you should be able to adjust your barrel at end of brake to tighten cable some. Unscrew it to make it tighter.
    then as mentioned you can do a search on "how to adjust bike brake levers range"
    and see a video for that specific item.
    How to Adjust Bike Brakes - YouTube
    that is good one to see.
  1. Next step for fixing rattling brakes
    By dirty_vegas in forum Brake Time
    Last Post: 06-09-2013, 08:01 AM
  2. Replies: 3
    Last Post: 05-10-2012, 06:10 PM
  3. calibrating your Garmin for a 29'r?
    By raceboy in forum 29er Components
    Last Post: 02-23-2012, 03:46 PM
  4. Replies: 10
    Last Post: 06-16-2011, 12:09 PM
  5. Calibrating cycling computer for Fat Bikes
    By stevelei in forum Fat bikes
    Last Post: 01-04-2011, 09:43 AM
