Results 1 to 5 of 5
    Is this a good deal?
    I've found a 2006 Stumpjumper (not disc or anything) that's almost brand new for $750.
    Is this a good buy? I've heard people say the frames of the 07 and 08 are far better.
    FS or hardtail?
    Reputation: 006_007's Avatar
    Quote Originally Posted by chowfun89
    If it is the same as this one I found here:
    http://www.daviswheelworks.com/bikes...tumpjumper.htm
    then not a bad deal. Granted the stuff is an 06, but it is all solid parts, and the wheels appear to be disc compatible so IF you decide to upgrade you do not need to purchase different wheels. If it is from a bike shop I would go for it, from a private seller maybe offer a hundred or so less initially?
    Sorry, it's a hardtail and its from a private seller.
    I've also found a 07 stumpy ht comp thats in very good condition. I'm trying to negotiate with the seller a price. If he can do $850 or so I'll def buy the 07 vs the 06 (:
    My LBS had the '08 Stumpy with the M5 frame,very nice except it had pretty cheap components for a $1500 bike,like Avid SD-3 V's and an LX/SRAM X7 drivetrain.Don't get me wrong those are decent,but not for $1500.I suspect you're paying for the frame and Fox forks for the most part.Anyways,if you can get one of the bikes you mentioned that would be a good deal, especially if you can talk one of them down a bit
