Results 1 to 9 of 9
Thread: Going tubeless
    Jun 2013
    Going tubeless
    Is this conversion somewhat easy to do? Bike shop said labor was 30\wheel and id prefer to not do that. It can't be that hard. I'm not a knucklehead.
    Is this something i can do myself with no knowledge of tubeless?
    Sent from my XT907 using Tapatalk 4 Beta
    Very easy. Get some Stans tape, valve stems and sealant. Follow the directions on the web site and you shouldnt have any problems.
    Resident Gear Head
    Reputation: provin1327's Avatar
    Mar 2013
    I did two 29" wheels with Gorilla tape, 2 presta valves, and some Stans sealant for $35, much cheaper than a $75 stans kit + 60$ in labor. It's easy
    Tech Tuesday: Gorilla Tape Tubeless Conversion - Pinkbike
    2 Hands Working Do More Than 1000 Hands Praying
    Climbs = necessary evil
    Reputation: rogerfromco's Avatar
    Or buy the Stan's Kit and do it yourself. There are a ton of videos on youtube.
    Reputation: shiggy's Avatar
    Dec 1998
    Going tubeless
    Quote Originally Posted by TheRoweShow View Post
    If you are using tubeless tires on tubeless rims it is easy.
    If not, it can be a huge PITA and may not work at all.
    People that tell you DIY "tubeless" is always easy, that you can do it with any tire or rim, or it solves all your traction and flat problems are knuckleheads.
    mtbtires.com
    Jun 2013
    I have a 2013 specialized carve sl with 2bliss ready tires so i think I'm a little better off.
    Nov 2012
    Very easy to convert as long as everything is tubeless compatible/ready/or UST. You may need access to a compressor to get a good seal on some tire/rim combos.
    Nov 2012
    Oh, and get the Stan's valves as you can remove the stem and replace the fluid with out separating the bead. A process that you will have to deal with every 2-4 months. Assuming your tires last that long.
    Dec 1998
    Going tubeless
    Quote Originally Posted by LB412 View Post
    Most tubeless valves have removable cores.
    Get the valves made for your rims.
    mtbtires.com
  1. Replies: 4
    Last Post: 04-22-2013, 02:24 PM
  2. Replies: 2
    Last Post: 02-11-2013, 06:25 PM
  3. Running non-tubeless ready Racing Ralphs TUBELESS?
    By trumpus in forum Wheels and Tires
    Last Post: 02-07-2012, 11:28 AM
  4. Replies: 5
    Last Post: 01-29-2012, 08:42 PM
  5. Replies: 5
    Last Post: 02-15-2011, 12:30 PM
