Results 1 to 6 of 6
    Oct 2013
    New question here. Going from 160 to 180mm rotors.Please HELP
    Hi everybody,
    I currently have tektro Io mechanical disk brakes with both 160mm front and rear rotors.I am doing a bit harder riding so my 160s heat up fast.I would like to know if i could put 180mm on the front and a new 160mm at the back without buying anything extra(besides rotors).Could these fit:front:Shimano SM-RT56 180mm,rear:SM-RT56 160mm​.Thanks
    B A N N E D
    For future reference: http://forums.mtbr.com/brake-time/
    You'll need the correct 180mm adapter on the front.
    Front IS 180mm: http://www.bikeman.com/BR8913.html
    Front PM 180mm: http://www.bikeman.com/BR8593.html
    Those rotors you listed should be fine .
    Oct 2013
    Thanks very mutch will buy adapter.
    Depending on how much you plan on spending, you might want to save up for a few months and buy a whole new set of brakes. SLX taken off from new bikes are pretty common now. Could be only $200 or cheaper.
    You could keep the old brakes for when you sell the bike. May be something to ponder.
    Quote Originally Posted by AntonioLekic View Post
    Hi everybody,
    A couple things you'll want to check into -
    Make sure your hubs have 6-bolt mounting pattern for the rotors rather than Shimano centerlock style (you probably do).
    Those rotors say 'for resin brake pads only'. Not sure why this is, but you should either run resin pads or at least find out why they recommend them before ignoring the recommendation. (I found resin pads can be kind of grabby myself.)
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    B A N N E D
    Quote Originally Posted by slapheadmofo View Post
    Good point, I forgot that some Shimano rotors are made for resin only pads.
  1. Pugsley and 180mm rotors - no match?
    By hssp in forum Fat bikes
    Last Post: 07-22-2013, 12:58 AM
  2. help with 180mm rotors on Blindside..
    By PHRESHKHID in forum Transition Bikes
    Last Post: 10-05-2012, 09:23 PM
  3. 203/185mm rotors with 200/180mm adapters?
    By FM in forum Brake Time
    Last Post: 10-21-2011, 12:30 PM
  4. Swapping 185 stock rotors with 180mm ashima
    By eddie80 in forum Weight Weenies
    Last Post: 07-25-2011, 08:10 PM
  5. 180mm rotors w/ Avid Juicy 7's possible?
    By ovenmit331 in forum Brake Time
    Last Post: 01-08-2011, 04:26 PM
