Results 1 to 13 of 13
    Reputation: maxxdout's Avatar
    Giving Managers Bike a Tune-up
    My manager asked if I could tune his bike up for a few bucks (I should have said I'll do it for free if he gives me a raise, ha!) and I accepted the offer. I'm going to pick it up tomorrow and get to work. The thing is, what does a general tune-up include? I'm going to check the tire, brakes, shifting components, suspension components, make sure everything is tight but loose, true the wheels, lube everything, then clean it off good. He says he hasn't rode it in years. It's a Cannondale full suspension bike (not sure what model) and it's still like brand new, so I assume this will be an easy tune-up.
    Is there anything else I should check? Thanks!
    Jan 2011
    Quote Originally Posted by maxxdout View Post
    Tight but loose? If the bike was built correctly in the first place the only thing it should need depending on how much he actually rode it would be deraileur adjustment. Also depending on where the bike was stored it could need a new chain and tires/tubes from being stored outside.
    Also if the bolts for the suspension pivots aren't obviously loose don't mess with them they have specific torque specifications so they don't bind or squish the ball bearings. Another thing, you might already know this... When you clean it only wipe it down with windex or something similar, hosing it down will expose the bearings in the suspension to rust.
    bi-winning
    Reputation: rkj__'s Avatar
    Check derailleur hanger alignment.
    Check / adjust derailleurs
    Check / adjust brakes / inspect pads for wear
    True Wheels
    Check / adjust hubs
    Check / adjust headset
    Check BB for wear / play
    Measure chain wear / lube
    Check all bolts and fasteners
    Maaaaan
    Reputation: Ericmopar's Avatar
    Aug 2003
    My only tip is clean it first then lube and check everything, not the other way around.
    Cleaning can aid finding cracks etc, plus you don't want dirt getting into hubs or anything else you might take apart to grease and lube.
    Communist Party Member Since 1917.
    Tell ya Manager due to you needing a raise at your job your gonna need to borrow some friends tools to do a tune-up for him but you'll get the job done for him. Do a good job and maybe it'll stick in the back of his head and he'll give u a raise in the near future
    Thanks for the tips. I'm sure he stored the bike inside, he claims its like brand new.
    Another thing he asked me: is it possible to convert the presta valve to a schrader?
    Another thing he asked me: is it possible to convert the presta valve to a schrader?[/QUOTE]
    Is that a question for us? You might want to research this first before asking...Might catch flack since you are taking the bosses life in your hand, liability at least?
    Well yea, he asked me but I told him that he would probably need different rims because of the size of the hole of the valve, but I would look into it. I'll probably end up just giving him one of my presta to schrader adapters (if he doesn't have one already)...
    Your very brave.
    Well it's not the manager of the store, just the department, and he's a cool guy (he claims I'm one of the best in the dept. )
    You'll get half of what he said he'd pay you and you will get twice the work load...because you are so good...
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Not sure I'd want to do bike work for my boss. However, I think you're on the right track with what to do.
    Clean and polish the bike well. Throw on some Pedro's Bike Lust. Toothbrush-clean that bike. I detail almost every bike that I work on. Delivering back a clean bike leaves a good impression and sets a very positive tone. Basically, people are superficial. They judge your work by what they can see.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Easy, just drill it. Sheldon says 21/64" drill bit, but I think 11/32" is plenty close enough and I'm not sure how many hardware stores carry 21/64" bits.
    Drill carefully!
  1. Keeping the Peace with the Land Managers
    By DaGoat in forum New Mexico
    Last Post: 12-11-2010, 11:17 AM
  2. Land Managers Meeting
    By Mtn. Biker123 in forum New Mexico
    Last Post: 04-08-2009, 04:03 PM
  3. Olympics meet the land managers
    By Dave_schuldt in forum Washington
    Last Post: 04-14-2008, 06:53 AM
  4. What bike Brand Managers do when we're bored...
    By downhilljill in forum Haro
    Last Post: 08-01-2007, 03:54 PM
  5. Paging bike shop owners and/or managers
    By Mellow Yellow in forum Passion
    Last Post: 03-06-2005, 02:13 AM
