Results 1 to 3 of 3
    Jul 2013
    Giant XTC 2 Fork change?
    I have a 2013 giant xtc 2 29er. I was wondering if I could change the fork to a higher mm? I have the rock shox recon 100mm on it now. Would changing the fork to a higher travel effect the frame or Geometry?
    That's a 71.5 degree head tube angle XC bike with steep last gen geo. 120 will slacken it slightly and make it less twitchy on faster downhills. It will slow up the steering a bit. You can also use an angleset headset to change the HT angle. It probably will not hurt the frame.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Quote Originally Posted by varcity23 View Post
    Generally, yes, going to a longer travel fork will effect the geometry. Some forks have a longer axle to crown (distance from center of axle to crown of fork) than others.
    Your fork has 526mm Axle to Crown. The Manitou Tower pro has an a-c of 530mm so it would barely effect the geo of the bike.
    I wouldn't go for much more than 120mm.
  1. Did Giant change the Talon 0 29er mid season?
    By chuckeieio in forum Giant
    Last Post: 06-26-2013, 05:54 AM
  2. DIY FORK change ...Please help...!
    By pingmonster in forum General Discussion
    Last Post: 04-24-2013, 09:49 AM
  3. To Change Fork or Not?
    By aizen in forum Shocks and Suspension
    Last Post: 03-21-2013, 04:06 PM
  4. Giant Roam XR1 suspension change
    By TX-Shooter in forum Giant
    Last Post: 09-24-2012, 08:57 AM
  5. Possible Fork Change for my HD
    By Salespunk in forum Ibis
    Last Post: 07-24-2012, 10:40 PM
