Results 1 to 10 of 10
    Dec 2012
    Getting things to stick to your handlebars
    I have some lights and a horn to put on my handlebars (I commute in a large city), but even when I screw them as tight as I can, they do not stay, especially over bumps. Can I superglue them, or is there some other way to make them stick and stay firm?
    29er
    layer of friction tape on the bars first
    Dec 2012
    Quote Originally Posted by Dan GSR View Post
    I see. Hmm...you mean like over the entire bar?
    29er
    Just under the lights and horn
    Piece of inner tube around the bar under the mount works well.
    Jan 2013
    rubber inserts for headlights
    the BV headlight set I got included rubber inserts that help keep them in place. pretty good deal at about 11 bucks. if you don't want to get another light, then try finding something rubbery, or maybe try winding a rubber band under the mounts.
    29er and 26er
    Mar 2012
    Quote Originally Posted by Slash5 View Post
    This is what I do. It also helps from my light and bell scratching my bars. Good luck!
    Reputation: Bikemaya's Avatar
    Sep 2012
    Zip ties can do wonders too! You gotta get a bit creative sometimes
    Oct 2010
    Well my Smarty answer is JB Weld but I seriously use old pieces of rubber tubing...blue locktight on metal screws/nuts sometimes.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    You could take an old inner tube and build up the bar area a bit before you install the clamp. Also the idea of hanging the light under the bar instead of on the top is a pretty good solution if you can keep the cables out of the way.
