Results 1 to 5 of 5
Thread: geared to SS ?
    geared to SS ?
    Hello all. Thanx in advance for the help. I have a FS geared bike now that i broke the derailer hanger on going uphill. I was wonderong how labor intensive it would be to make it a SS. I figured since its down it would be a good time to do it. Or should i just look for the HT SS that i really want.
    Reputation: iceboxsteve's Avatar
    Feb 2012
    A FS SS? I suppose that is not unheard of? I had a hardtail that I did the same thing to and it was a quick easy fix. Granted I got lucky. Most likely your dropouts aren't correct so you'd either have to get lucky like with chain length or add some sort of tensionor.
    When I say lucky I mean I made it work with a wee bit of tall gear and a half link, and when I got the chain it it was the tightest thing in the world, and I turned it into slop within 3 months.
    My advice is to look for a true SS (I just bought one and can't describe the fun I have on it).
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    For FS SS, you usually need a spring loaded tensioner with LOTS of capacity to pick up chain slack - because chainstay length does not remain constant. It has been done but few really want to.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Most hanger are replaceable ,your lbs should be able to get one or there is a company that makes them , tpye in deraileurs hanger on google. Depending on the frame to convert to ss it could be easy.There are a couple of tensioner that would work Paul and Yess are two. Go to the ss forum type in full suss ,lots of bikesthave been done.
    Jan 2009
    Derailleurhanger.com
    It can be done. Check the singlespeed forum.
  1. ss vs geared
    By Markleo in forum Singlespeed
    Last Post: 02-19-2013, 06:09 AM
  2. How geared should a new guy be?
    By DannyPacMan in forum Apparel and Protection
    Last Post: 02-10-2013, 06:54 AM
  3. What to do? SS or geared?
    By Eric Z in forum 29er Bikes
    Last Post: 05-07-2012, 12:05 PM
  4. 24hr duo SS or Geared
    By Milli in forum Endurance XC Racing
    Last Post: 08-11-2011, 07:24 AM
  5. Geared to SS?
    By morningmist in forum Singlespeed
    Last Post: 05-08-2011, 07:47 PM
