Results 1 to 6 of 6
Thread: gear issue
    gear issue
    So I just got a new Scott Aspect 60 and I was riding around getting used to it. And every time I was in a certain gear it would make a clicking sound. If i was in 7 on one and 2 on the other it was click. Does that just mean I have to adjust the derailluer? Or should I take it back to the shop. Most gears run smooth and some just dont. It was the first actual time i took it out on a good ride. Any help would be appreciated.
    Fat-tired Roadie
    Nov 2007
    Depends on the reason for the sound.
    If it's the chain dragging against your front derailleur, you may be able to tune it so it doesn't do that. Check out parktool.com for instructions for tuning derailleurs.
    Because 7 is your largest cog, it's possible that it's just too extreme a position to get working. In which case, don't use that gear combination - shift it into 1 in front, and whatever gives you the right amount of resistance in the back.
    Sounds like your deraulier was never properly adjusted, since you just bought the bike I would just go back and let them do it.
    That depends.
    If you're riding a 10 speed group set, then I would expect that middle ring in front and 7 in the back might be fine to expect no chain rub.
    If you're running 7 or 8 speed, then you are experiencing chain rub. It is normal. Shift.
    For example instead of being in 2/7, shift easier in the back by a gear or two, then shift UP in the front to the big ring. Same results, minus the chain rub.
    Since the bike is new the chain takes about a month if you ride a lot to fully stretch out. So what's happening is you'll have to keep readjusting your deraulier when it gets misaligned until your chain is fully stretched out. Also the cables loosen up which causes it to and again that is just part of the break in period.....normal!
    Cable stretch is normal. Chain stretch shouldn't occur until the chain is wearing out after hundreds of miles.
  1. Skills problem - Mind blocking or Gear issue ?!?
    By drapeado in forum All Mountain
    Last Post: 04-18-2011, 10:18 AM
  2. Replies: 3
    Last Post: 06-10-2009, 04:47 PM
  3. Voodoo 29er Single gear front/Multi gear rear??
    By motocross93 in forum 29er Bikes
    Last Post: 03-12-2009, 09:12 AM
  4. Back Paddle Gear Shifting Issue
    By keith6945 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2008, 02:29 PM
  5. The issue with the "grany gear"?
    By easyperson in forum General Discussion
    Last Post: 12-27-2007, 09:51 AM
