Results 1 to 10 of 10
    Gear Adjustment Limit Screws
    Although I rode for about 6 years in the early 90s I never bothered with any kind of maintenance. Having recently got a new bike I figured this time I would get to grips with proper maintenance - the advent of youtube and forums helps massively in this..
    Having watched a video on the proper adjustment of your front derailleur I adjusted mine and managed to get the gears to shift more fluidly. Up until this Sunday when I found I could no longer get the big ring (not good as I stay on the big ring pretty much 95% of the time).
    I adjusted the cable tension, although I think I overdid it as when I next went for a ride my indicator told me I was on the middle ring despite being on the big one. I eased of the tension and now there is a rattling noise. I have tried fine tuning the tension with the ring on the shifters but can't get rid of this rattle. Pressing the shift-up lever fully home makes everything perfect but in it's default position the rattle returns.
    Now - I know the limit screws are to fine tune the cage but on mine they don't seem to have any effect. How much do you need to turn the limit screws - a couple of turns? Also is there a way to reset the limit screws if they get too far out of whack?
    Reputation: TwoHeadsBrewing's Avatar
    The BicycleTutor site has been very helpful to me, and the video will explain how to adjust the front der.
    http://bicycletutor.com/adjust-front-derailer/
    The limit screws aren't for fine tuning. They are just for what they say, setting the limits of movement each way. The one labeled "L" sets how low the der. will go down. The screw labeled "H" sets how high the cage will go (sounds like this is the one you needed to adjust out a hair). Fine tuning the pull of the cable is done with the barrel adjuster.
    Reputation: Adim_X's Avatar
    I experienced a similar issue on a friends old Specialized Hard Rock. No matter what I did the deraileur would not push the chain onto the big ring. It actually turned out, his crank had become loose, and the sprocket was out further than it should of been. However he never noticed this while pedaling. It was kinda strange.
    Thanks THB that is the video I watched when I adjusted 1st time around.
    MDC - yes that's what I though. I figured that the derailer cage must be slightly in the wrong position as it is hitting the chain whilst the chain is moving through the cage. When I said the ring on the shifter, I meant the Barrel Adjuster - I'm not up on the terminology. I will try some more barrell adjusting. Thanks
    If all this fails I'll check the crank bolts.
    Cheers
    Old man on a bike
    Videos can be nice but they're not always done well or complete in scope. You might review the front derailleur adjustments here http://www.parktool.com/repair/readhowto.asp?id=75. Your issue with the adjustment is most likely just from the new cable/housing bedding in a bit, and you may need to loosen the anchor bolt for the cable for correct tension rather than just with the barrel adjuster.
    suum quique
    Thanks for the link.
    "It is possible that the front derailleur will rub the chain slightly even on properly adjusted bikes. This is likely on some bikes when riding in the largest sprocket in front and the smallest cog in back" - www.parktool.com
    So I might not be able to remove the noise completely. Using the barrel adjusters I have reduced the rattling to some degree but like the quote above says I do stay in the highest gear a lot of the time so some rattle might be expected.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Quote Originally Posted by JacGT
    just shift gears properly
    Honestly... ahh I give up
    Quote Originally Posted by highdelll
    OK - thanks for that insightful response.
    ~Disc~Golf~
    you're welcome
