Results 1 to 7 of 7
    full suspension always noisy?
    Found some video this weekend of guys doing drops on full suspension bikes that were not cut with music. Are all full suspension bikes always so noisy? Maybe it was drive train rattle and not the suspension but they actually sounded like they might be falling apart but it sounded like more noise than just a derailleur. I've got an old rigid mtb and a cross bike so I've not ridden trails on any kind of suspension yet, so maybe all bikes sound like this but I really got the impression that it was the rear linkages making a lot of noise.
    depending on the bushings/bearings, how well greased, what kind of shock... you can get noises. if you are getting noises, you may want to do an overhaul. I know mine is making some creaks and groans now and then, so soon it will get its bushings greased.
    No they are not all noisy. Yes there is usually drivetrain sound, same as hardtails.
    Tight + Twisty = Tasty
    Earn your turns!
    Oct 2010
    My FS bike is ancient and fairly low-end (2001-ish GT iDrive 6.0), and it's quiet, so I can't imagine newer and higher-end suspensions would be loud. You get chain rattle like you do on any bike over roots and such, but you don't really hear the rear suspension working any more than you hear the forks working, if that's what you're asking.
    It's possible big drops might cause the shock to make some noise as it soaks up the impact, but in normal riding I don't hear a difference.
    Quote Originally Posted by 97Ultra View Post
    ah, yours probably uses bushings, and is either not used in wet conditions or mud terribly often, or you have been very careful with the hose when spraying off.
    basically if your fs bike squeeks, give it grease. serious grease, like mobil1 synthetic chassis grease for cars. its a touch heavier than bike specific grease, but far longer lasting and is designed for much higher loads and speeds and washoff pressures and temperatures than bike greases. all that for a tiny touch less slipperiness.... another tip, use this good and thick in your headset and bb, and never worry of those again.
    addicted
    Reputation: willrace4food's Avatar
    Jan 2009
    raw video from bike mounted cameras can also pick up sounds and magnify them a lot more then you would actually hear.
    Professional Speed Bump
    Reputation: captainjoon's Avatar
    You're talking about chainslap noises and "snaps" from rear suspension, etc. The noises resonate through the frame and amplifies them as well.
    On landing...all bikes will make loud noises.
  1. Suspension seatpost with full suspension bike?
    By Haystack Calhoun in forum Shocks and Suspension
    Last Post: 07-21-2008, 04:54 PM
  2. full carbon full suspension 29er
    By suvowner in forum 29er Bikes
    Last Post: 07-15-2008, 02:22 PM
  3. Ever combined suspension seatpost with full suspension bike?
    By 250savage in forum General Discussion
    Last Post: 08-15-2005, 06:06 PM
  4. hardtail with suspension seatpost vs. full suspension
    By d3vil in forum Beginner's Corner
    Last Post: 06-18-2004, 07:56 PM
  5. seatpost suspension vs. full suspension bike
    By Mike_Rides_Red in forum Shocks and Suspension
    Last Post: 05-24-2004, 07:34 PM
