Page 2 of 2 FirstFirst 1 2
Results 26 to 32 of 32
  1. #26
    Reputation: jkidd_39's Avatar
    Sep 2012
    Pumped it up to 260psi. What an amazing difference!! It's a whole new bike. Now I can push up hills. No more soft tail.
    I guess I was right about the rear shock being too soft.
    I'm ready to go hit some more trails!!
  2. #27
    Let us know how your ride goes with the psi set at 260.
  3. #28
    Sep 2012
    Quote Originally Posted by CaTiRo View Post
    I got about 80% travel out the bar 2.1. I put my rebound in the middle. I'm gonna play with the psi over the new few rides then once I find a good point I'll really tweak the rebound.
  4. #29
    Keep in mind you won't use all your travel on every ride.
  5. #30
    Sep 2012
    Quote Originally Posted by Garasaki View Post
    Correct. The local trail I rode last night is mostly hard packed dirt with a lot of roots. I am gonna try to ride a long more technical track tonight and see how the rear feels. If I can get it to continue to climb like it does right now and remove a little of the hard tail feel over roots I will be in business!! I think turning down my rebound a click or two should help.
  6. #31
    Sep 2012
    Subbing... lots of good info here.
    Personally I don't see the point of a 29'er... then again I'm 5'5"
  7. #32
    Sep 2012
    Anyone able to walk me thru rear shock removal??
    I can't get my shock off. I got 3 bolts off but the four will not come off. Just spins.
    I can't find any walk thru's on removal.
