Results 1 to 5 of 5
    Dec 2008
    Front wheel removal for 07 Specialized Enduro
    Could someone direct me to a link that gives instructions on how to remove the front wheel? The fork is specialized own brand.
    Thank you.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Assuming it's a 9mm quick release, you open the lever and then have to unscrew the fixing bolt a few turns to clear the lawyer knobs.
    Dec 2008
    Quote Originally Posted by whodaphuck View Post
    Thanks for the reply
    Not a quick release mechanism like the rear wheel.
    Hard for me to describe…
    found the manual online but still cannot figure it out.
    http://cdn.specialized.com/OA_MEDIA/...rk_English.pdf
    Moderator Moderator
    Loosen the small pinch bolts first, then unscrew the axle and pull it completely out of the hub and dropouts. Wheel should fall right off. Reverse the procedure for installation. Don't forget to snug up the pinch bolts or you'll lose them. Don't overtighten them either - it's very easy to strip those threads and then you're into drilling and heli-coiling your fork.
    Yes, that's fonetic
    Feb 2005
    Quote Originally Posted by johnd11 View Post
    It's right there on page 7. Just do the opposite of the hub installation procedure.
  1. Need help with front wheel removal
    By dford3520 in forum Bike and Frame discussion
    Last Post: 05-21-2013, 04:07 PM
  2. Swapping axles on a Spinergy Enduro front wheel?
    By Mountain Cycle Shawn in forum Wheels and Tires
    Last Post: 10-22-2012, 12:59 PM
  3. best non front wheel removal bike rack for pickup truck ??
    By vyper005 in forum Cars and Bike Racks
    Last Post: 07-16-2012, 08:47 PM
  4. Replies: 11
    Last Post: 03-06-2012, 10:19 PM
  5. New SLX Front Derailleur hits chain on Specialized Enduro
    By pressingonward in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-29-2011, 09:34 PM
