Results 1 to 11 of 11
    Jul 2013
    Front vs. rear wheel upgrade
    I want to get a wheel but can only afford one. Should I get a front w/tire or just a rear?
    Reputation: time229er's Avatar
    Oct 2013
    why?
    2014 Nail Trail 29...
    A front wheel will have the biggest potential impact on your riding experience. Especially if you have a bike that needs a better fork. Like all the bikes sold with X forks.
    Those Suntour forks weigh 6.2 lbs.
    A decent air fork can drop 2 pounds off the front of your bike. Add a light wheel with 15mm thru and a good light tire. You will have a transformed bike maybe 5 pounds lighter.
    And it is way cheaper to build a front wheel yourself. A very good way to learn.
    30mm inside hookless carbon rim with Sapim Lasers/brass nipples.
    Bead hook-less rims carbon 29er light bike rim tubeless compatible, outer width AM 35.00/30.00mm & XC 27.00mm - carbon rim (beadless) - Carbon Bicycle,carbon frame,carbon rim,carbon wheel,carbon wheelset,carbon mountain bike,carbon road bike CarbonBi
    Jan 2013
    Quote Originally Posted by bluntrager View Post
    I would go with a front wheel first and start saving money for the rear immediately.
    Reputation: Clicker1's Avatar
    May 2012
    Keep saving until you have the money to buy a wheelset.
    I don't see the point in replacing a random wheel. If you don't know which wheel to replace they don't need replacing. Save your money for something worthwhile like a fork.
    Sent from my 831C using Tapatalk
    Jul 2013
    Quote Originally Posted by ou2mame View Post
    Here's why:
    I've bent my front rim twice in the last three weeks. Once on a drop, the other cornering too hard. I weigh 220 on bontrager duster rims. The wheel bending caused me to wreck both times. This is my first season riding at n* and so I'm sure they--and I--won't last long if I continue to use them. Thus, there is the reason. I figure I can just ride a bit smoother until I can afford both wheels, it'll work out well.
    I was more or less just trying to get feedback on which wheel people would upgrade if they could only do one and why.
    Anyways, I went ahead and got a wtb frequency i25 rim laced to black dt Swiss comp 14 gauge spokes and a gold hadley hub for the front. Time to start saving for the rear and a fork.
    Also, are the any 650bx2.5 tires besides the wtb breakout?
    or any really good 650b dh tires for that matter?
    Dec 2010
    Maxxis Minion DHF is incredible for the front. I'm using a Honey Badger on the rear; it's surprisingly capable and it survived a day at Keystone with no problems. But the DHF is really really great for the conditions I ride here in Colorado: lots of loose gravel on hard pack and big rocks.
    Jul 2013
    UPDATE: It's a good thing I just got the front wheel because the LBS called me earlier today to let me know that my front rim was bent beyond re-true. Really stoked to be getting the wheel new wheel in the mail soon!
    Anyways, I am riding a 2014 fox talas 34 ctd, so it'll cost some big money to really upgrade the fork and I wanna get that rear wheel taken care of first. Thank you to everyone for the fork advice though.
    As for the tires, Maxxis High Roller 2 might make its way there, but I'll definitely look into the DHF, conditions sound similar to CO.
    RAKC
    Reputation: tigris99's Avatar
    Not sure why u would be recommended a fork when running those forks already. Forks are fine. Wheels for some reason trek seems to think those wheels are best for bikes when they can't withstand crap if u weight more than 170lbs.
    Get the rear wheel, and then rude it like u stole it and don't worry about upgrading anything unless u break something else.
    Sent from my Nokia Stupid Phone using Tapatalk
    Finally!
    Reputation: Terranaut's Avatar
    Jun 2014
    Did you simply try more air in you tires? If you bottoming out and wrecking the rim you jyst need more air. I am 220 and never bottomed out once.
    Sent from my SGH-I747M using Tapatalk
  1. Replies: 7
    Last Post: 01-09-2016, 02:07 PM
  2. Upgrade.....Front/Rear Derailleur and Shifter
    By NC-Biker in forum 29er Components
    Last Post: 09-09-2013, 05:26 AM
  3. any suggestions for rear wheel upgrade?
    By weekendthrasher in forum General Discussion
    Last Post: 08-27-2013, 01:08 PM
  4. any suggestions for rear wheel upgrade?
    By weekendthrasher in forum Specialized
    Last Post: 08-27-2013, 08:49 AM
  5. Converting rear wheel (10mm) to a front wheel (9mm)
    By WeAreTheCosmos in forum Wheels and Tires
    Last Post: 06-21-2013, 03:46 PM
