Results 1 to 32 of 32
    Reputation: Whason's Avatar
    The front and the rear brakes
    Did a quick search and didn't find any responses, but have seen on other threads comments made by very experienced riders about how they never use the front and rear brake together, and that "control" etc etc is better if you use the front or the rear alone in many situations. I tend to use both brakes together the majority of the time, and would like to know from people that are advanced enough to use one or the other separetly how they use it and in what situations. For making turns more sharply? Also, in what situations are you supposed to use one or the other instead of both?
    "Chancho. When you are a man sometimes you wear stretchy pants... Its for fun..."
    Reputation: Nubster's Avatar
    I use one and both. I am far from advanced and don't use the brakes to accomplish anything other than slowing down but sometimes I just feel like the front brake is all I need and on steep dissents I will use the front mostly but also use a little rear just to take some pressure off the front. I just pay close attention to make sure my rear doesn't start sliding or locking up. I may be wrong in how I am doing it but so far works for me. My new bike will have larger better brakes so I am not sure how things will go with them.
    Reputation: clutch_08's Avatar
    on really really steep hills i try to stay of the front brake so i dont go over the bars.
    the rest of the time i use the front.
    local jackass
    Reputation: biggoofy1's Avatar
    i use both together with no issues its all about modulation and your placement on the bike
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    2009 Cannondale Synapse 5
    Down East Cyclists
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    If you use both brakes at the same time, your bike will explode.
    Honestly... ahh I give up
    Big Mac
    Reputation: mbmb65's Avatar
    When going uphill, I use the front brake. Downhills I use the rear only. On flats I use both. I also have a negative brake that I use sometimes.
    Quote Originally Posted by highdelll
    I thought only carbon fiber bikes exploded though?
    Reputation: Highwaystreets's Avatar
    this is true... if you are going fast enough you may also go back in time... its a sequel to "hot tub time machine"
    Current Rides:
    Trek Stache
    Reputation: Kaba Klaus's Avatar
    Quote Originally Posted by Whason
    I think what they really mean is that they have learned to apply different levels of force on each brake lever at any given point in time and hence can use both brakes independently (but usually together) to control the bike.
    I would recommend "Mastering Mountain Bike Skills" or fluidride vids etc for some discussion on braking technique.
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
    Reputation: Kneescar's Avatar
    ~Disc~Golf~
    wow, I learned alot
    local jackass
    that guy sure does like to touch himself
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    Down East Cyclists
    Quote Originally Posted by biggoofy1
    Don't we all?
    Professional Speed Bump
    Reputation: captainjoon's Avatar
    Who needs friggin brakes?? I lean forward and use my fingers to stop the wheels from spinning.
    Muahahahaha~
    Reputation: NoVA_JB's Avatar
    I tend to use the rear brakes more than the fronts. I really only use my fronts going uphill if I have to stop or if going really fast and just the rear are not stopping me fast enough.
    My bike has a larger rotor in the front which leads me to beleive I should use the front more often.
    ~Disc~Golf~
    Quote Originally Posted by NoVA_JB
    ~75% of your braking power is in the front
    I always thought too much front brakes could send you over the bars. I'll have to try it today.
    On smooth downhills what you do is you put all your weight on the back wheel by pushing your butt back all the way behind the saddle and brake with both front and rear.
    On rough downhills, put all your weight back like above but use more rear brakes.
    You won't go over the handlebars.
    I usually use 75/25 front/rear on smooth leveled.
    50/50 on smooth downhill.
    25/75 on rough leveled.
    approximately 10/90 on rough downhill.
    almost 0/100 on steep (over 60 degree grade) downhill.
    ...never mind all that I said above. I don't use brakes! I use my fingers! Muahahahaha~
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    only if:
    1. your weight is towards the front of the bike
    2. your front wheel encounters root, rock, ledge, rut...anything that will slow your front wheel while on the front brake...
    soooo...basically if your weight is back (think butt behind the seat on steepy sections) and and you release the front brake when your wheel hits anything that will slow it down you will not go over the bars (99% of the time)....
    as highdell stated....MOST of your braking power comes from the front....and should not be neglected...that's where a lot of bike control comes from while descending.....
    PS - careful on the front brake descending switchbacks.....better to go into the corner slower and accelerate out....using the front in a tight radius really F's up your handling.....
    Click Here for Forum Rules
    Quote Originally Posted by captainjoon
    Muahahahaha~
    I actually found on recently like in the past 2 weeks of riding that when i go around turns that if i use both brakes at the same time I have less control and cant make the turn as fast. I started using the back brake only while going downhill and really noticed a difference in the speed and sharpness that I can take the turns. I usually only use both brakes now if I am going in a straight line and need to stop quick. Otherwise I only use the front if I am on flat gournd and slow down gradually, just not to fast so I dont flip over the bike.
    AIM - ATLMTB90
    Get at me
    bah...just go here:
    http://sheldonbrown.com/brakturn.html
    jeebus......
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by CHUM
    bah...just go here:
    jeebus......
    Actually, I think your first post was better advice for mtn bikers. Sheldon Brown is aiming mostly for roadies - who rarely have to use the rear brake at all.
    At mtn biker doing steep rocky ledges, where the front wheel gets airborne and then lands, better not grab a handful of front, or it will put him OTB - as pretty much all of us have had the misfortune to prove at one time or another.
    Then there's the IMBA unfriendly lock and slide the rear wheel around the switchback move, popular among those who race, or wish they could.
    Old enough to know better. And old enough not to care. Best age to be.
    Quote Originally Posted by Highwaystreets
    It must be some kind of mountain bike time machine...
    ~Disc~Golf~
    Ummm, we JUST talked about this?
    Reputation: Hellrazor666's Avatar
    Quote Originally Posted by Kneescar
    Don't we all?
    Yes and my fingers flitter when I touch myself
    1.. 2.. 3... 4...........FIFFFFFFF !!!!!!!!!!
    I tried more front brake today and my bike would sometimes submarine, granted my fork sucks and is in need of an upgrade. When it didn't submarine I found times I was in better control and others that I felt more comfrotable using the rear more.
    MTB skillz = NADA
    Reputation: GrayBeard Pirate's Avatar
    Dec 2009
    Yes, too much front brake will send you over the bars, but I have noticed that applying only my back brake on downhill portions doesn't do much in terms of slowing me down. I use enough back brake to just about lock it up, and then gradually apply front brake to bring me to a quick stop. Granted, the first few times my bike exploded, it hurt, but I am starting to get used to it.
    Since I don't like writing, I don't have a blog to pimp. This space for rent.
    The only time I use the front brake is going downhill. I only slight engage it though just enough to slow down a bit accompanied with there rear breaks
    Reputation: traffic002's Avatar
    Dec 2008
    On steep descents, my rear brake does nothing because it is in the air. I've learned to feel the front and use it to its limits.
    On aggressive single track, I use the brakes to help shift my weight. Sometimes I need to delay turn-in on a corner by a fraction of a second and the brakes can help me with the delay.
    I tend to use the front brakes more if I need to haul my speed down. I use the rear brakes to adjust my weight balance and to assist in turn-in.
    Just get out and ride!
    Quote Originally Posted by Nubster
    Hey! Where'd you get this photo of me?
    That's me on my Hardrock at Bedrock.
    Reputation: Gasp4Air's Avatar
    Sophisticated riding/racing techniques might lead you to use different mixes of front and rear brakes to accomplish things like controlled drifts and such, - but for for most of us, most of the time, just use both brakes. As someone pointed out, most of your stopping power comes from the front. That's why riders who mix tires always have the fatter, knobbier one up front. Relying on the rear, for fear of an endo , especially on downhills tears up the trails and is not a good general practice. Learn to use the front. Also pointed out by someone is the need to keep you weight back when you brake - the harder you brake, (and the steeper the pitch) the further back you need to go. And avoid locked elbows at all times - they lead to the plant you most want to avoid on the trail - the face plant.
    Besides lever force and scooting back, start thinking about when to break. On technical trails, I try to brake on the smoother sections, and allow the bike to roll thru the difficult chunky parts. On turns, I brake before the turn, roll thru and perhaps accelerate out of it, depending on what's ahead.
    And like everything else, technique gets better with practice.
    Use it, use it, use it while you still have it.
