Results 1 to 5 of 5
    Front Derailleur Setup
    I just picked up a Deore FD from Jenson, which was not in its original packaging but is supposedly still brand new. After mounting my new FD I put new jagwire shifter cables on, went to start setting it up and my High and low adjustment screws seem to have no effect on the FD. I've done some research and can't find anything to remedy the problem. I have tried adjusting it with and without cable tension and it still has no effect. Could anyone direct me so I can get a ride in tomorrow?
    T.W.O.
    Reputation: mimi1885's Avatar
    Did you buy the right one? Top pull vs bottom pull?, Some Shimano can do both so check your cable routing.
    Check youtube ,park tools or Sheldon Brown for set up. Maybe put the old one on for tomorrow.
    I don't see how that is possible. If you use your hand to force the derailleur to the outside chainring and adjust the Hi limit screw, you should be able to feel the limit screw moving the cage.
    Depends what you mean "has no effect". If the derailleur is setup correctly the limit screws will not seem to do anything.
    Park Tool Co. Front Derailleur Adjustments
    Thanks for the reply guys, after a bit more research and some more time fiddling with it I was able to adjust it. I got a little frustrated too quickly and jumped the gun posting on here. Rode 12 miles today and it didn't miss a beat.
  1. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  2. Can an XTR 3x9 front derailleur be used in with a new 2x10 XT setup
    By breakcontact in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2013, 06:44 AM
  3. front derailleur setup
    By giant_in_a_trance in forum General Discussion
    Last Post: 09-12-2012, 02:18 PM
  4. XTR M981 triple front derailleur - use for 2X setup?
    By CactusJackSlade in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2012, 11:45 PM
  5. Need help with Blur front derailleur setup
    By BCosgrove in forum Santa Cruz
    Last Post: 03-13-2011, 11:17 AM
