Results 1 to 12 of 12
    frame with dent, stay away or buy?
    i dont do any heavy riding.. light trails and around the lake on a paved road. Do you think this frame is ok to ride or should i stay away? thanks for the help guys
    heres a link to the post
    Salsa Spearfish 29er Frame - M
    My question would be, how come the manufacture didn't offer a crash replacement to the owner. Instead he's selling it...there may or may not be more to the story. I've had frames that I dented but I knew what, how & when it happened, I personally wouldn't buy a didn't frame.
    Reputation: tahoeyeti's Avatar
    Oct 2003
    It's fine structurally. You just have to make sure that you're ok with it cosmetically for the price.
    not really an mtbr member
    Reputation: theextremist04's Avatar
    ^You can't actually know that. I'd be wary about a dented aluminum frame.
    Flow like water
    Reputation: DavyRay's Avatar
    I'll take it, if you are afraid of it. That dent looks like it is all of 3mm deep, by perhaps 5mm long. Insignificant, in my opinion. A Spearfish frame is not going to vaporize because it has one small dent in it.
    Edit: It's a medium. I take a large. Otherwise, I'd be all over it. I got to ride a Spearfish this past weekend. That was an eye-opener. You would be wasting this bike on asphalt paths.
    $500 seems way too much
    carbon full susp stumpjumper frame for $500-700 on ebay.
    Specialized FSR Stumpjumper Comp Mountain Bike Frame (small) | eBay
    Trail Ninja
    Reputation: Varaxis's Avatar
    I personally think a dent in that area is fine for that kind of tubing and material. I'm no material science major and don't know much about that frame, but I've seen other frames ride just fine for 1+ year with worse looking dents, even through hard riding on mtn bike parks. Downtubes from reputable brands should be thick to take that kind of damage. I'd ride it. Reminds me that I need to get some downtube protection for my bike.
    bob, I like how they made that carbon frame look like it was welded.
    thanks for the help and responses!
    derp
    Reputation: danielsilva's Avatar
    A bit expensive for what it is but i wouldn't mind that dent, i rode much worse and never had a problem. I would monitor the dent but i wouldn't be freaked by it.
    2006 Cannondale Rush 650b
    2010 Cannondale Trail SL 650b
    2013 Norco Range Killer-B
    CSC
    CSC is offline
    I wonder how one would dent the frame like that w/o chipping the paint...seems "fishy".
    As far as material strength goes, aluminum can deflect quite a bit before it fails...it's more ductile than steel.
    I'd personally avoid a bike with a dent...surely there are other good frames for that price tag w/o frame damage. Scratches are ok, but dents...not my thing.
    Here's a tension test my materials science class did with a piece of Al rod (plastic/non reversible deformation begins at ~8,400 Lb/f):
    EDIT: yeah, it's tension, not compression (as would be the case here...in a bike frame), but the information is still interesting.
    i've had a lot of dented frames... before mtbing i did bmx for years.. always had dented stuff. never had anything brake. well, i broke wheels, broke forks, but not a frame.
    Save Jesus
    Reputation: beanbag's Avatar
    All u need to do is to check the welds at the joints like head tube and bottom bracket. That top tube is not going to fail in the middle because of that dent. Well, check that the top tube is straight at least.
