Results 1 to 19 of 19
Thread: Fox Shox
    Reputation: Antares's Avatar
    Fox Shox
    Most of the best bikes out there seem to have them equipped. What is it, specifically, that makes them the best? Or, one of the best?
    T.W.O.
    Reputation: mimi1885's Avatar
    R&D, Martketing, Test riders, User testimonials, price. There are other products out there that some would consider better but not as popular. In general, they are good bench mark.
    ...idios...
    Reputation: SteveUK's Avatar
    There's no such thing as the best; which is especially useful to bear in mind when somebody tries to sell you something, or is telling you to buy something.
    Diogenes
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Quote Originally Posted by SteveUK
    In a market one of the products has to be the best for a specific user. I'm not saying fox is or is not the best, but one product has to be better even marginally. It depends on what each user wants, but I agree with you not to follow someone's advice blindly.
    There is not much choice between rotten apples.
    locked - time out
    Their product managers do a great job giving great prices on them for the oem supply.
    ...then when you need service, they hit you on the back end ALWAYS for a new crown/steerer/stanchion unit for $250.
    Pure genius.
    Rod
    Rod is offline
    Oct 2007
    Quote Originally Posted by glitz
    Pure genius.
    I had this happen to me so I'm sending my fork somewhere else for service.
    mostly hype.
    you pay a huge amount of money for a fork that isnt damped well for you and cant be adjusted. your only option is sending it in to someone like push to get it setup for another couple hundred bucks.
    the RLC and RC2 dampers are good dampers, but those are only coming on extremely expensive bikes. usually a bike will have a crappy R or RL fox 32, which is a unadjustable noodle mostly using the name to help sell the bike. dont get sucked into the name, the other brands forks are just getting better and better. shocks too, ill never own another non serviceable fox shock!
    their stuff is reliable though..
    Feb 2010
    I also think that it has to do with the many different types of shocks they make for many different industries. Their experience has to be superior just for that fact. I also run Fox on my utv's and atv's. IMO!
    T.W.O.
    I agree
    Quote Originally Posted by rapdaddyR
    Fox learns from different divisions it certainly help them. Fox dominate the rear shock in MTB, a few companies has tried but never really make it stick. However RockShox is coming strong I have it on my Blur LTC and I'm very impress so far.
    As for the forks, that's a different story. There are so many good companies to choose from. RockShox, Magura, Manitou, Marz, Maverick, etc. They offers different feature that would fit your budget and personal preferences. Especially high-end stuff Fox is not the only player there are a lot of stiff competitors.
    I like Maverick because of the simple user serviceable, plushness, and lightweight, but I also own fox, RS, Magura, Marz, and manitou. From my personal experience Fox is definitely not the best not by far.
    Thanks for all of the input guys. I guess it really comes down to how you feel about the shocks after you have tested them personally. Right now my '07 Trek Fuel EX 5 has some stock Rock Shox Toras and I like them but I know that there are shocks out there which greatly exceed these.
    No. They don't. Especially if you actually maintain your fork.
    To the OP, Fox hit the market when pretty much all the other options were low quality or had poor dampers (RS was both). Fox also does not make a low end fork, and all the guts of their forks are machined aluminum. The other manufacturers have been playing catch up pretty well, but Fox's dampers are still as good as anything out there.
    You also have people calling them noodles, but that's only compared to some of the new, very stiff forks coming out now. When the Fox 32 first came out, it was the stiffest XC fork you could get, and they're still plenty stiff.
    Fox forks are still some of the most serviceable, and Fox is very happy to sell parts direct to the user (try that with RS). If you don't get the fully adjustable RLC, the damping can still be adjusted by playing with oil viscosity, and can always be re-shimmed (which a smart user can do), but the base setting works well for most people.
    Their seals suck though, but easily remedied.
    The fact is Fox forks offer a very compelling combination of weight and performance, and they did it well before the other manufacturers.
    locked - time out
    No, people are maintaining them, with no apparent wear and damage, and they are still being told they need new uppers.
    Sorry, but your opinion doesn't matter much when your knowledge apparently comes from reading this thread:
    My fox fork rebuild experience
    Fox forks eat their stanchions when either the bath oil becomes exhausted or when it run for longer periods with contaminated oil. Both of these problems are solved via regular maintenance. Do the maintenance, no new uppers needed. If the bushings do eat the stanchions, the wear is not visible unless the lowers are removed.
    Underskilled
    Reputation: CaveGiant's Avatar
    Wow a bit of Fox thrashing in this thread.
    However the general gist is spot on Fox WERE the top forks out there a few years back.
    RS is catching up.
    Forks are generally known to be very plush with great small bump absorbtion (gives you better traction/grip)
    They are also releasing a new stanchion coating (hopefuly confirmed at sea otter in a few days) which may up the bar again.
    Fox forks are great, but you get what you pay for, however so are Tora's.
    If you go from a Tora to a high end Fox you will never look back.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Any first hand experience with this ? Anything that counters the excellent service and performance that I always get from Fox and And Fox customer support ?
    T.W.O.
    I agree, what's a seal remedy
    Quote Originally Posted by bad mechanic
    May be you can help me, bought my fox 80 Terralogic a while back it was their top of the line fork, certainly top of the line price. It started leaking but the seal after about 5 mo, sent the fork in 3 times already each time fox warranty it, but problem still remain. I just leave it now and wipe the seal, though I wish I can fix the problem, or just change the fork out, it's a waste though cause I have may be 600mile on the fork that's it. I wish I can fix the seal.
    <a href="http://www.flickr.com/photos/17268606@N06/3084582324/" title="CIMG1136 by al1885, on Flickr"><img src="http://farm4.static.flickr.com/3004/3084582324_4dc319a367_b.jpg" width="1024" height="768" alt="CIMG1136" /></a>
    meow meow
    Reputation: b-kul's Avatar
    its kind of like an xt rear deralliur on a bike. it is something to make the bike look better than what it is (in some cases). you need to look carefully at what fox fork you are actually getting.
    Reputation: sanjuro's Avatar
    Sep 2004
    I think this is the easiest thing to notice for beginner buyers.
    Remember when Manitou dumped their entire line of Minute forks on the intraweb? It became impossible to know if you are getting a good Manitou or a bad one.
    T.W.O.
    Thanks, bad mechanic for the PM on the seals.
    I wish Fox would make an aftermarket version of DCRV shock though. I had a few rides on the GF Roscoe and I really the action. It's like Dhx air with Rp23 weight and simplicity.
