Results 1 to 46 of 46
    Reputation: sgtcurry's Avatar
    Mar 2011
    Fork replacement?
    I want to replace the fork on my bike and I was looking at performancebike.com and they had the Rockshox Recon Silver TK that I can get for about 150 after taxes. My current bike has a Suntour SF-11 XCM V3 right now. Is it a worthy and good upgrade for the price?
    Haro Sonix LT VL120
    Prolly. Your fork weighs about 5.6lbs and the recon weighs from 4.5-4.9lbs. Also, the recon has lockout and I don't think yours does. I would say it would be a good investment overall for that price. Maybe you could even sell your fork and get some money back.
    Mar 2011
    Good point thanks. Totally forgot I can sell it. I am think $50 for the fork? The fork on my bike hasnt even seen 10 miles.
    Reputation: mullen119's Avatar
    The Recon silver is a decent upgrade over what you have. But if you search around and raise your budget just a little bit, You can find a fork that will blow the Recon away. You want to try to find a rock shox fork with Motion Control, not Turn Key. Also look for any Manitou fork that is a 2010 or newer(a Minute expert, Drake, or Match). Those will be best fork upgrades at a reasonable price.
    Mar 2011
    I just called the performancebike store and they said the only had a Rockshox recon se I can't find any info on it.
    Quote Originally Posted by sgtcurry View Post
    They probably meant SL. If thats the case, buy it.
    Mar 2011
    Ahh ok thanks I will go out today and buy it.
    Stores don't always carry what is on the website. There's a Performance store 40 minutes away from me that carries Fox forks. The one 10 min away has the Recon and the Tora SE, but no Fox. It really depends which one you call.
    Order it online and get free shipping to the store since it's over $150.
    2009 Access 9.5 29er
    2010 Diamondback Insight RS (700c hybrid)
    Velorazzo frame build (26)
    Its going to be an upgrade even if its a TK. But if it has motion control, It will have twice the performance of the TK version.
    Mar 2011
    So I went to the store and its a Air suspension. I have never used a air suspension so I decided not to buy it today and go back home to research. Now my questions is how do I set it up? Also It doesnt have motion control.
    Haro Sonix LT VL120
    Air is great as you can set the spring as high or low as you want. You use a shock pump to add air to the air chamber until you get the right amount of sag. I'll look around for for for you.
    Haro Sonix LT VL120
    This one's a little more money at $300 http://cgi.ebay.com/RockShox-Rock-Sh...item35b20caf15
    And this one's a good deal if you don't mind used http://cgi.ebay.com/Rockshox-Recon-R...item3f0a316732
    Mar 2011
    Ahh ok so I need a shock pump as well? I can get it at the LBS for 160 total including tax its a 2011 model. I am not sure If I want a used fork so much.
    Haro Sonix LT VL120
    I can understand that. Shock pumps will cost you about 20 bucks or so depending where you get them. LBS will prolly be a little more. If you buy the fork there, ask them to throw in a shock pump if it doesn't already come with the fork.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    That used Recon has a 6.5" steerer tube. That's pretty short. I doubt it would fit.
    Reputation: jpeters's Avatar
    I have a friend with that fork and he loves it for xc.
    Haro Sonix LT VL120
    Yeah I have a Recon 351 uturn that I used for a while (replaced with a Revelation) and it really was a great fork.
    CT3
    CT3 is offline
    Hoodwink
    Reputation: CT3's Avatar
    May 2010
    i have a recon race xc with remote lockout on my avalanche, its light and just as good as my fox f32r on my sensor. it was new came with shock pump so you may not need to buy one
    Reputation: Gsromich's Avatar
    I have the 2008 recon race that is a great fork. It is air which is nice and very light. It replaced a suntour similar to yours and it is an amazing upgrade. Motion control is great. No problems with the fork so far.
    "A day without sunshine is like, you know, night."
    Steve Martin
    Mar 2011
    Well I bought it today and have yet to install it because I have a ride tomorrow and I dont want to mess with my bike before a ride.
    Haro Sonix LT VL120
    Oh man I would work all night if I had to to get that on. It should only take an hour at the most.
    Mar 2011
    Yea I just want to do it right I am afraid i will screw it up
    Haro Sonix LT VL120
    Not much to it. Just unscrew your brakes, unscrew the top cap, take off the stem and any spacers you have. Cut the new steerer tube to match the old one and install the bearing race and star nut. Put the fork through the headtube, install spacers and stem. Tighten the top cap to preload the bearings till there is no play and then tighten down the stem and install the brakes. Done.
    Dirt Abuser
    Reputation: Bail_Monkey's Avatar
    Save up more money and get a mid tier fork like the Rockshox Reba. There are a variety of settings on the fork, you will be able to dial it in to a variety of riding conditions.
    "Don't ride faster than your guardian angel can fly"
    Mar 2011
    So with the help of my father I got the crown off and on and everything was fine until I was measuring to cut. My old fork was cut at 7.5" and I read around that I dont want to cut under 8" if I ever want to resell it so I have to wait till tomorrow morning so I can run out to my LBS and get some spacers.
    Mar 2011
    Also could some one link me to a guide or something on how to adjust the travel on this fork? The included manual didnt say much. I have never gotten an Air suspension fork either so I am a little lost.
    Reputation: Nenbran's Avatar
    Dec 2010
    http://www.sram.com/_media/pdf/rocks...cal-Manual.pdf
    I think the travel adjust bit is around page 15.
    Mar 2011
    Thanks.
    Cool great fork congrats let us know how you like it.
    Every fork I own has a steerer under 8 inches.
    Haro Sonix LT VL120
    A good trick is to put a spacer on top of the stem and put the top cap on top of the steere tube, that way you still retain steerer tube length but the stem is still at stock height. Like Mullen119 said, most steerer tubes get cut down to 7-1/2 anyway but adding spacers is a good idea.
    Here's a good example
    Mar 2011
    I didn't think to put the spaces on top. Good idea thanks. I just bought some spaces a few minutes ago.
    Haro Sonix LT VL120
    Quote Originally Posted by Bail_Monkey View Post
    BTW Rebas are top of the line for Rock Shox
    Haro Sonix LT VL120
    Nice. Half inch of spacers on top will be fine. I wouldn't go any longer though cause it ends up being a rather hard post sticking up waiting to hurt you somehow. BTW the extended steerer tube gives you a place to hang you hydropak!!
    Mar 2011
    Good point as well. I will be finishing it up in a little bit and I will tell you guys how it is.
    Mar 2011
    Ok so I finished it and I took it to my nearest park to test it out. It was great! Compared to my other bikes at least, I have only ridden on the Dart 2 and the Suntour XCM and the cheapo walmart bikes before and this is a totally different beast compared to those. Rides so much more smooth than any of my other ones, also the lockout is a nifty little feature and I havent been able to bottom it out yet unlike the others. Now I can't decide what I want to do next with it. I am thinking about swapping the Alivio Rear derailleur, to a X-9 or XT.
    Awesome
    Aug 2010
    Did you install the star nut yourself? I am thinking of upgrading my fork from the stock fork but am alittle intimidated by the star nut.
    Mar 2011
    Yea the star nut was worst Part of it. The crown took a while I mean a long while since I didnt have a specific tool for it. But the star nut I had to basically get a socket wrench that was a bit smaller and had to use that to hammer the star nut in.
    Lets see some pics please
    Mar 2011
    I'm on vacation with my family for memorial day and wont be back until monday so no pictures till then. Though I do want to ask what would be the best upgrade from where I am sitting that gives me the best performance. I am thinking X9 derailleurs and shifters. Or maybe a new crankset and cassete.
    EDIT: My budget leftover from the fork and bike puts me at about $100-$125.
    IMO, X9 is overkill. X7 is very good and can be had at reasonable prices. Just dont go down to X5.
    Mar 2011
    Quote Originally Posted by mullen119 View Post
    Doesnt really seem like much of a difference in price on ebay. Plus I would rather not have to do too many upgrades, because I bought a Motobecane 700HT a few weeks back and already needed to upgrade. But my father got into it to so I decided not to upgrade that and bought a new bike that I could upgrade when needed.
    If you can get X9 for the same price as X7, then it makes sense for sure. they usually run about 50 bucks more for an X9.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    1) I hope you bought the fork to use it rather than sell it. If you want it where it's at, I would cut it rather than leave a 'nad-catcher' on there if you don't need it that high.
    2) Shimano shifters (or any shifter that would work with your Alivio rear derailleur), is not compatible with an X9 rear derailleur, or any other rear derailleur from SRAM. You can only use Shimano rear derailleurs with your present shifters.
    3) I would save your money until your derailleur breaks. It really isn't going to make a significant difference. If your getting bad shifts now, that won't change. It will be very slightly crisper, but nothing that will make you go "Whoaaaa!"
    If you're dying to invest in your hobby, there are some accessories that you may not have that could make your riding more enjoyable / safer.
    multi-tool
    pump (mini or floor)
    camelbak
    riding shorts
    good thin wool socks
    riding shoes
    hi-performance fabric jersey
    light windbreaker that will stuff into a jersey pocket
    helmet with better ventilation
    gloves
    spare tubes
    seat bag
    Grips bars shifters tires DR pedals shoes you could get all kinds of stuff. I would go with the crank and or slx cassette. What bike do you have?
